Author Topic: 2014 v-strom knocking back cylinder?  (Read 7224 times)
Offline pdc3161
  • Bike: Suzuki v-strom 1000 2014
« on: November 04, 2015, 05:30:22 »
Hi all I've finally got my 2014 v-strom 1000 in for investigation as it has a bad knocking noise since its 1st service only when it is hot ? We have tried changing oils to no effect so it looks like engine out job
I will keep you all informed as to out come as it is all being done on warranty thank F I have told them not to give me it back till knocking noise has gone
Also I have been to hammer & tongue in Warrington asking about a power comander they tune it on a rolling road to your bike they said it will give me
15 bhp mid range
4 to 5bhp  top end it will eliminate all stalling at low rev and back fire now and then that we all seem to have because it's running so lean I know a lad that had his done and he said it's like riding a different bike it's so smooth all the way threw rev range
I have a mivv end can on and putting a k&N filter in when I get bike back and have this done it cost £480 all in I know it's a lot but I hope it will be well worth it
Offline Hondaman
  • Bike: 650 L3
Re: 2014 v-strom knocking back cylinder?
« Reply #1 on: November 04, 2015, 09:24:03 »
Knocking after the first service doesn't sound good. Makes you wonder if someones forgotten to refill with oil before starting....
15hp midrange sounds an unfeasibly large increase from the pc but I stand to be corrected, let us know how you get on :)
Offline Roadrocket
  • Live to ride, ride to live
  • Bike: Suzuki DL1000AL4ABS + DL650K5
« Reply #2 on: November 07, 2015, 11:10:30 »
I might be wrong but this sounds like Idle hammer - the cause - play in the clutch/flywheel bearing from poor manufacturers, a well known issue with TL's SV1000s and DL1000s, there is a company that overhauls and cures the problem.
Offline SimonW
  • Bike: DL1050XT
« Reply #3 on: November 07, 2015, 15:01:45 »
Sounds like it might be idle hammer to me too. Did it start only after the first service?
Roadrocket - I didn't think anyone had come up with a definitive diagnosis of what causes idle hammer, but that the consensus was crankshaft end float. I don't recall anyone coming up with a fix - are you confused with clutch chudder?  :shrug:
Edit: WhereTF did that avatar come from?
Online UK_Vstrom650
« Reply #4 on: November 07, 2015, 15:30:04 »
FR is assigning Avatars to anyone who doesn't pick one...
Offline Roadrocket
« Reply #5 on: November 07, 2015, 19:28:54 »
My understanding the knocking is play between the flywheel and clutch? The flywheel on the Veek is heavier ? I could be wrong
Offline pdc3161
« Reply #6 on: November 09, 2015, 07:39:57 »
Hi all thanks for your thoughts? I thought the same but the newer model has a slipper clutch and yes it only started after my 1st service 600 miles  :shrug: it's a deep knock sounds like big ends but it's not and it's coming from back cylinder pull clutch in still the noise still there put it in gear under load still there if it was clutch it would go ? So stumped me should find out soon I HOPE
Offline SimonW
  • Bike: DL1050XT
« Reply #7 on: November 09, 2015, 09:13:02 »
Yep, definitely sounds like idle hammer. Mine does it too, but I don't notice it anymore. (Unless someone posts a message about it, then I remember I have it!) It's really weird that it only starts after the first service.
Offline Relevant11
  • Bike: Dl1000L4. KTM XCF 350, Royal Enfield interceptor 650( yes they are as good as they say)
« Reply #8 on: November 12, 2015, 08:00:23 »
I think there's a couple of threads on this very topic on  stromtroopers,the owners site in the USA
Offline pdc3161
« Reply #9 on: January 02, 2016, 19:01:17 »
Well hi all and a happy new year  :obscene-drinkingchug:
As promised a update of my v-strom DL1000 2014 knocking noise after 1st service well good and bad news ?
My bike was took in under warranty for investigation and ended up being stripped right down I was showed all parts big ends crank etc etc all was perfect so the bike was put back together every nut bolt torqued to the precise settings and voila  :violence-smack: it now perfect no knocking at all like new again  :clap: SO bad news I don't know what was causing it only its a torque not right as a guess I'd say clutch as its a slipper clutch and are torqued very high as when cold was running perfect once hot leaves a couple thou gap creating enough room to make the knocking noise ????
Offline Pedro41
« Reply #10 on: January 02, 2016, 19:36:39 »
Hi,
Pleased the bike is running good again - and all costs were covered. :)
Just thinking about your plans to swap the end can and chip the bike.
Unless its done by a Suzuki dealer it will affect the remaining warranty and possibly
insurance cover. You may want to check with them first.....
« Reply #11 on: January 02, 2016, 19:51:07 »
There was a mouse trapped in there knocking to get out. It escaped upon disassembly. You'd be surprised how often that happens.
Online TLPower
« Reply #12 on: January 02, 2016, 22:20:31 »
'Twas a duck Greywolf.
Looking for its beak. :)
OP I'm glad you're sorted and happy.
