Best way to wire in extra lights...
Pages:
3
Topic: Best way to wire in extra lights... (Read 19772 times)
0 Members and 5 Guests are viewing this topic.
Asmith61
Bike: 2011 B-King 1300 , 2023 Harley Nightster 975
Re: Best way to wire in extra lights...
Reply #40 on:
November 14, 2015, 22:15:53 »
That's brilliant I will change them then, I still have to fit my hot grips I haven't had time yet, with the lights they go in to the strobe flashing first so I have ordered a switch I hope that will cure it.
bigpie
Site Donator
Bike: DL650
Reply #41 on:
November 14, 2015, 22:50:55 »
There are mods to remove the low and strobe 'features' either by shorting a couple of pins on a IC or removing it completely.
biglad
Bike: DL650 L3
Reply #42 on:
November 15, 2015, 08:04:58 »
Yep, mine work fine on just one take off point. Its a 2A fuse I've got in it. No probs yet!
I read about soldering pins together to remove all modes other than hi but my knowledge isn't enough to do it. Its no hassle for me to switch the handlebar switch on and off twice when I stop the bike so when next time I switch it on it comes on in hi mode.
B..
Asmith61
Reply #43 on:
November 15, 2015, 12:30:54 »
Hi big lad and hi big pie, as I said I have ordered a switch so hopefully I can stop the strobing ( well not stop it but control it) big pie as I have the lights already wired in to your fuse board ( which is a brilliant bit of kit I might add ) could you please advise me the best way to wire in the switch ? And big lad I will wire in the hot grips this week many thanks.
biglad
Bike: DL650 L3
Reply #44 on:
November 15, 2015, 13:57:36 »
Heres how I did my wiring..
Negative from the fuse box to both negatives of the lights. I twisted all 3 wires together and soldered them.
Positive from the fuse box to one wire from the switch.
Positives from both lights to the other wire from the switch.
B..
bigpie
Site Donator
Bike: DL650
Reply #45 on:
November 15, 2015, 14:26:52 »
As above.
bazza72
Bike: 2016 Yamaha MT-09 Tracer
Reply #46 on:
November 17, 2015, 00:20:38 »
I had a set of these given to me as my brother bought them and 2 lots turned up. I fitted them to the engine bars some shape as the total lack of adjustment made it awkward to focus them.. Then after a few rides out I removed them as they were a pain because they would go out of sink, one would be hi beam and one flashing then one lo beam and one flashing and so on. Bit of a potch you can do without before setting off. Also they were falling apart and the supposed stainless Allen key bolts rusted! Whilst I will agree that oem stuff is a total rip off, the saying you get what you pay for Is right in this case..
Asmith61
Reply #47 on:
November 17, 2015, 17:10:08 »
Hi Bazza I haven't given mine a proper test yet,it is a pain having to go through the strobing thou, as you said you get what you pay for, I will see how they go if they fall to bits I haven't lost a lot of money that's the way I see it many thanks
king1
Bike: 2014 vstrom 650
Reply #48 on:
November 23, 2015, 17:48:56 »
One question about all this, does it matter what size wire you use, when wiring them up.
I have used 8 amp wire.
Asmith61
Reply #49 on:
November 23, 2015, 21:59:51 »
Hi mr king the wire I used was quite thin (sorry not sure of the amps) it matched both the wire that came with the gree lights and the switch.
arran66
Bike: DL1000 2015
Reply #50 on:
November 30, 2015, 17:39:44 »
Lights plus relay and inline fuse with a handlebar switch I've got the givi s310 mounted to crash bars straight to battery
Vic929
Reply #51 on:
November 30, 2015, 18:37:33 »
Ditto Arran fitted givi lights yesterday excellent quality and they look smart , connected the green switch wire to the rear brake connector for an ignition feed
Tris
Bike: V-Strom 1000 K8
Reply #52 on:
October 11, 2017, 14:03:49 »
Sorry to bring back a dead post but I’ve bought some of these lights and the you doe bar switch has 3 wires not two. How do I wire them from the aux fuse box please
Pages:
3
