Uprated Spring for lowered Glee
Topic: Uprated Spring for lowered Glee (Read 881 times)
madasadad
August 24, 2015, 22:25:47 »
I've my bike lowered 35mm at the rear and 18mm on the front, however the bike is quite wallowy, due to the lever effect of the dogbanes. Is it possible to uprate the rear spring, or better still, where would I go to source one?
2013 650, full Trekker luggage, Givi Airflow, heated grips, scottoiler, hyperpro Spring
Hondaman
Bike: 650 L3
Re: Uprated Spring for lowered Glee
August 24, 2015, 22:43:52 »
35mm at the rear sounds a big drop, especially if the fronts only been lowered 18mm.
madasadad
August 24, 2015, 23:20:14 »
35mm was what was quoted by the Honda dealer that did it. I don't think the front can go much lower. Stability is fine 2 up
greywolf
August 25, 2015, 03:55:37 »
The maximum the rear can be safely lowered is 28mm unless the shock travel is limited. For the best aerodynamics, the front should be lowered the same amount as the rear but the safe maximum on the front is 21mm unless the fork travel is limited.
madasadad
August 26, 2015, 11:14:05 »
The kit came with dogbones and what appeared to be a bushing to possibly restrict suspension. I've asked the supplying dealer to confirm
http://www.streetbike.co.uk/wp-content/ ... 154013.jpg
greywolf
Reply #5 on:
August 26, 2015, 18:07:00 »
That bushing does look like it is meant to limit shock travel. It would go around the shock shaft at the bottom between the lower clevis and the lower rubber bumper.
madasadad
Reply #6 on:
August 26, 2015, 20:48:05 »
I'll check, if it ever stops raining!
