Ha just checked that before reading this but thank you, yes this was blown, so the 30amp replacement was replaced. But when I place the key in the ignition, kill switch off, the fuse blows again. I have nothing else drawing power from the battery or from the switch less the lights (on by default).
I did just before of the incident took place attempt to put my beams on as instrument panel cut-off then came back, then cut-off again...by the second time round the bike had slowed to a stop (with the clutch lever depressed). Conditions weren't great, very wet spray on the m4 before our meet (group of 3) then headed to Penderyn, stopping having a quick 10min de-brief (ROSPA rider, which the bike stopped and started fine. Then after 5mins heading north heading into the clouds, dodging sheep, horses and cows this happened....and died in all the best places
http://goo.gl/maps/ek8u0.
So I'm thinking now lights, ignition...earth etc..which could be causing this.
