Author Topic: After playing with it a bit, it came away in my hand!  (Read 1480 times)
Offline Descolada
« on: August 15, 2015, 16:23:16 »
I was doing some maintenance and follow-up cleaning on my wee today when I noticed the rust forming around the clamp that joins the exhaust to the front pipes (see diagram).
I gave it a clean and as I was doing so it came apart in my hand - the rust had eaten through the part that faces down and onto the road.  :angry-tappingfoot:
Now, the worrying thing is that I can see no evidence that this is a simple clamp that can be replaced. Instead it looks like it is (was) welded to the pipe assembly - is this right?
I can get an exhaust clamp or a wide jubilee clip and replace it with that if needs be, but does Suzuki really expect you to replace an otherwise perfectly good exhaust if this clamp breaks?
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: After playing with it a bit, it came away in my hand!
« Reply #1 on: August 15, 2015, 17:46:33 »
Mine did the same in the wee. I replaced with with a normal clamp from eBay, you'll want to check, but I think it was 45mm to 55mm jubilee.
Offline Hondaman
  • Bike: 650 L3
« Reply #2 on: August 15, 2015, 17:57:17 »
If you replace it, get a proper stainless exhaust clamp (ebay) Mikalor (?) are a decent brand but check it has a stainless bolt - many just have a plated mild steel bolt
Offline Descolada
« Reply #3 on: August 15, 2015, 18:14:05 »
Thanks blokes, for now the jubilee clip is on as a work around. I will go take a look for a stainless steel version on fleebay.  :thumb:
Offline Descolada
« Reply #4 on: August 15, 2015, 18:23:30 »
OK, I think I've found it. The advert states;
    Stainless Steel Band
    (AISI-304)
    Zinc Plated Steel Bolt
    Beveled Edges
    Swiveling Bridge (ease of use)
    Suitable for High Pressure Applications
.. so "Zinc Plated Steel Bolt"
The link to the page is here;
http://www.ebay.co.uk/itm/MIKALOR-W2-Stainless-Steel-Hose-Clamps-Supra-Exhaust-T-Bolt-Marine-Clip-/221623600550?var=520480960102&hash=item3399cbc5a6
Offline Descolada
« Reply #5 on: August 15, 2015, 20:37:05 »
Just checked the diameter at the point where the clamp was welded on - it's 44.72mm.
Offline bigpie
  • Site Donator
  • Bike: DL650
Offline Descolada
« Reply #7 on: August 20, 2015, 17:00:13 »
The bracket arrived today and was fitted in 5 minutes. Big sturdy bracket - me likie.
