Author Topic: DL1000 Beyond Economic Repair -What next?  (Read 1310 times)
Offline Crustyle
« on: August 05, 2015, 16:12:20 »
My trusty steed threw its chain this morning, and in doing so broke off a piece of the engine casing where the clutch bolts in. The bike is a '57 plate and I've racked up just short of 80k miles. I reckon the bike's value is below that of the cost for a replace and re-build of the engine and casing. There's also a couple of other niggles I've been ignoring too - permanent neutral light, permanent F1 fault code - C44 (O2 sensor) which is not affecting the running of the bike, 10mm of additional vertical free play in the rear suspension when the bike is on its centre stand. Oh, and I've had to patch up the joint between the end cans and the pipes. it's looking a bit tatty too after 6 winters worth of commuting.  It has served me superbly, but its time to say farewell. So, I think I'm looking at disposal options. What does the forum reckon?  Sell as a project? Sell for spares? Sell to a parts specialist? Viking funeral?
Offline krisv
  • Bike: DL650 K5
Re: DL1000 Beyond Economic Repair -What next?
« Reply #1 on: August 05, 2015, 16:23:52 »
Check out the for sale section. There are 2 DL1000 engines for sale. A quick engine swap perhaps?
Offline Oop North John
« Reply #2 on: August 05, 2015, 16:30:29 »
Maybe buy something like this (seen on facebook)
http://www.gumtree.com/p/cars-vans-moto ... 1127936259
take off any bits that are any use on the old bike, and then flog the rest on ebay.
Offline Crustyle
« Reply #3 on: August 05, 2015, 18:08:02 »
Quote from: "krisv"
If I was mechanically skilled enough to do it myself I would consider it Kris. A good idea, but not for me. Plus I'd still have the other issues niggling away, and carrying the scars from low-siding it at the roundabout after Sainsbury's (Chippenham) - got carried away grinding the pegs and went to far! lol.
Offline Crustyle
« Reply #4 on: August 05, 2015, 18:11:04 »
Quote from: "Oop North John"
John, that bikes a VERY tempting proposition - only 18k miles on a 06! I might just have to give the man a call.
Offline Sam
« Reply #5 on: August 05, 2015, 18:56:00 »
How bad is the damage to the engine casing?
I've heard of people snapping a chain & damaging the engine casing. Then doing a repair with metal epoxy resin. Seems to last well.
Offline Crustyle
« Reply #6 on: August 05, 2015, 19:01:42 »
Sam, I did bounce that idea off my friendly mechanic (I have used the stuff on non-stressed areas), but he was of the view that the hydraulic clutch mechanism would be putting too much strain on the joint - it's got to shift 6 clutch plates, repeatedly. I was inclined to agree with him. I wouldn't want to risk a clutch failure and potentially damage a new chain, sprocket and end up with the original problem after splashing out the dosh. Tempting thought though.
Offline krisv
  • Bike: DL650 K5
« Reply #7 on: August 05, 2015, 22:45:56 »
Quote from: "Crustyle"
Sainsbury's (Chippenham) - got carried away grinding the pegs and went to far! :).
Fair play mate. It is a good roundabout to get some lean on. Was it you on the silver/grey Vee usually wearing a hi-vis heading towards the M4 on the A350?
Offline Esmerelda
« Reply #8 on: August 06, 2015, 10:09:13 »
Post a photo of the damaged area,   it would help all to understand the extent of  damage.
Regards
Esme
The older I get, the faster I was!
Offline Crustyle
« Reply #9 on: August 07, 2015, 16:58:12 »
Quote from: "krisv"
Kris, Possibly, my bike is predominately black/silver-grey, usually filthy, and I do wear a faded high vis vest and white Caberg. I'm usually passing Chip around 7.40am, hail, rain or shine. Not any more though!
Offline krisv
  • Bike: DL650 K5
« Reply #10 on: August 10, 2015, 10:10:57 »
Yep, it was definitely you then. I was on the red wee heading towards Trowbridge. Let us know what you getting next and will keep an eye out for you.
Offline Crustyle
« Reply #11 on: August 10, 2015, 19:05:40 »
Ah Kris, so that's YOU on the red V - we've been passing each other for ages! Safe riding mate. :auto-dirtbike:
