What's this for?
Topic: What's this for? (Read 3051 times)
bigpie
Site Donator
Bike: DL650
What's this for?
July 18, 2015, 15:20:47 »
it's just above the front cylinder on a glee.
SimonW
Bike: DL1050XT
Re: What's this for?
July 18, 2015, 15:26:38 »
Joining wires together without needing to solder them.
Rusty Nuts
Manufacturer of iron oxide
July 18, 2015, 15:48:33 »
Is it the heated grips connector? Just behind radiator, left hand side?
ProfG
Guest
July 18, 2015, 15:50:21 »
I think this is a great subject for a weekly competition
Rusty Nuts
July 18, 2015, 16:03:13 »
Well, I was assuming there was a desirable and extravagant prize.
Descolada
Reply #5 on:
July 18, 2015, 16:59:45 »
I think it's the NSA tracking connector.
TLPower
Bike: ThunderBastard (KTM 1190 ADV)
Reply #6 on:
July 18, 2015, 17:02:03 »
There is and I've won this one fellas.
My prize is Bigpie carbon wrapping my bald 'ead. Good eh?
bigpie
Site Donator
Bike: DL650
Reply #7 on:
July 18, 2015, 17:22:09 »
It is on the left side, could be the heated grips connector, strange how the dealer the po bought it from wired the heated grips to a wire at the back of the bike instead of this.
greywolf
Reply #8 on:
July 18, 2015, 17:43:51 »
It is for certain the heated grip connector. The orange/green wire along with the connector shape are unmistakeable.
Hondaman
Bike: 650 L3
Reply #9 on:
July 18, 2015, 17:45:15 »
Which fused circuit is it fed from out of interest?
Phil
Rusty Nuts
Reply #10 on:
July 18, 2015, 18:12:26 »
I will pm you my address for the prize.
On second thoughts, if it really is desirable and extravagant, DO NOT POST IT!! Just send me a PayPal gift to the same amount.
greywolf
Reply #11 on:
July 18, 2015, 19:28:22 »
The heated grip connector runs off the signals fuse along with the turn signals and brake light.
Hondaman
Bike: 650 L3
Reply #12 on:
July 18, 2015, 21:08:24 »
Thanks GW
There does seem to be a few take off points around the bike, was never sure where they were supplied from but I haven't seen/noticed the grips take off near the front cyl
greywolf
Reply #13 on:
July 18, 2015, 23:20:06 »
That's the connector the Suzuki heated grips are designed to use. That doesn't necessarily mean that connector needs to be used for heated grips. I have HotGrips wired to a fuse block.
Kayaker413
Bike: 2008 650
Reply #14 on:
July 21, 2015, 10:53:54 »
Piggy backing this thread. I found a black connector front left on the inside of the faring, not far from the indy.
Hondaman
Bike: 650 L3
Reply #15 on:
July 21, 2015, 11:17:57 »
Are you sure that's not the temperature sensor?
greywolf
Reply #16 on:
July 21, 2015, 16:45:04 »
Left side would be the ambient air temp sensor. It only looks like a connector until you look at the front and see there are no connections.
Kayaker413
Bike: 2008 650
Reply #17 on:
July 21, 2015, 21:02:06 »
Madyokel
Reply #18 on:
July 26, 2015, 22:09:35 »
So if this is the heated grips connector, it would be nice to be able to get the other half of it so ones own grips or another accessory could just be plugged in. Anyone know what it is called or where to get it?
krisv
Bike: DL650 K5
Reply #19 on:
July 26, 2015, 22:17:54 »
The cable you need is called the horn lead wire.
http://www.robinsonsfoundry.co.uk/content/pages/shop/parts/Suzuki/DL%20-%20V-Strom/DL650/K4-K6%202004-2006/dl650k4wiringharness.htm
Item 12 on the list. I am not sure whether its the same for the Glee. Maybe Greywolf can confirm??
What's this for?
