Author Topic: Clutch & Brake Levers  (Read 1489 times)
Offline TarkMalbot
  • Bike: 2015 DL1000 ABS
« on: July 09, 2015, 20:01:52 »
What model and year levers will fit the 2014-2015 DL1000? Not many sellers seem to advertise for the new bike but I assume some others will be the same.
Thanks.
2015 DL1000 ABS with Grand Touring Pack. X-TRE, Speedo Healer, PDM60,  CREE U5 LED Spotlights, Puig Hugger, Puig Touring Screen and Multiregulable Visor,  Short Billet Brake & Clutch Levers, BS Motorparts Rad Cover, Scotoiler & R&G Shock Tube.
Offline 426hemi
Re: Clutch & Brake Levers
« Reply #1 on: July 10, 2015, 13:07:55 »
Hi,
Bought a set off Ebay, genuine Chinese but fantastic quality, £15 delivered, See item number below.
http://www.ebay.co.uk/itm/291405813386. Fits 2002 to 2015 models :)
Offline TarkMalbot
« Reply #2 on: July 10, 2015, 13:32:09 »
Cheers,
I was fully intending to go the cheap Chinese route as I used to stock a lot of them for the race bikes as they were good quality and cheap to replace in a crash.  Good to know they are the same from 2002 onwards as that widens the availability somewhat.
Offline Oop North John
« Reply #3 on: July 10, 2015, 13:38:09 »
For a 2008 DL1000:
http://www.suzukipartshouse.com/oempart ... ndle-lever
For a 2014 DL1000:
has different part numbers for the brake and clutch lever assemblies, though the actual lever(s) might be the same  :shrug:
Offline TarkMalbot
« Reply #4 on: July 10, 2015, 15:54:58 »
The fact 426hemi has successfully fitted some to his 2015 bike gives me confidence and I have ordered a set so will know in a few weeks time once they have get there way over from Hong Kong!
« Reply #5 on: July 10, 2015, 16:52:41 »
Agreed it's worth having a go at only £15.
Offline TarkMalbot
« Reply #6 on: July 22, 2015, 20:58:50 »
Arrived today. I am impressed with the quality.
Now I just need to see if they fit!  :fix:
« Reply #7 on: July 22, 2015, 21:15:13 »
Nice and shiny  :)
Offline TarkMalbot
« Reply #8 on: July 22, 2015, 21:50:46 »
Perfect fit! Took a little longer than expected due to the hand guards using the same mounting point and also the throttle cables were in the way so had to move the twist grip a little. Look lovey and feel great.
The only issue I have is that you can't move the mounts along the bar because of the hand guards and I would like to move them slightly. This was the reason I wanted the shorty shiny levers as to have my fingers where I would like on the clutch means my hands are right at the end of the bars.
