Author Topic: Fuel meter showing the wrong level  (Read 863 times)
Offline BadasH
« on: June 07, 2015, 09:46:47 »
Hello :)
I'm a bit of a newbie here and I have searched for a solution to my problem here but haven't found it. So sorry in advance if I ask about something there's already a thread for.... :)
My problem is this :
No matter how much fuel I put in my tank I can't get the top bar of the fuel meter to light up. I have not removed fuel pump or done anything else to it lately.
Thank you for any input and sorry if my English is a bit off :)
Regards, Arild :)
Offline bosnjo
  • Bike: DL1000 L7
Re: Fuel meter showing the wrong level
« Reply #1 on: June 07, 2015, 09:50:00 »
Your profile says you own DL1000, but not the year of the bike. You should update it so the other members could help you better.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
« Reply #2 on: June 07, 2015, 09:50:58 »
Arlid,
Don't worry about it. I have spent 10 years putting fuel in mine and half the time it only shows 4 bars again when I ride away, even if I "brim" it to the top.
Sometimes 4, sometimes 5. Worry more about how accurate it is at the bottom instead.
Also, head over to INTRODUCTIONS and say hello properly.
Offline BadasH
« Reply #3 on: June 07, 2015, 09:51:53 »
Oh, sorry :) It's been done now. I own a  2005 btw :)
Offline BadasH
« Reply #4 on: June 07, 2015, 09:52:43 »
I don't worry as much as it tickles my OCD :)
« Reply #5 on: June 07, 2015, 16:54:52 »
That's fairly common and the cause is a deterioration of the connection quality of the wiring inside the tank. The additional resistance causes a change in the reading. Some people have removed the fuel pump to access the connections and clean them up but most simply adjust their minds to the situation.
Offline NTBooth
  • Bike: Benelli Trk502x
« Reply #6 on: June 07, 2015, 17:33:17 »
Hi! I get this too sometimes, sometimes 4 sometimes 5 bars. Usually once I have brimmed the tank it takes 2 or 3 miles then the tank shows 5 - drops to 4 very quickly though. As others have said...as long as the bottom is OK you should be fine. haha...
Offline BadasH
« Reply #7 on: June 07, 2015, 23:25:41 »
Yes, This is a great bike so this is nothing ot complain about :D
