Author Topic: Valve clearance check DL650  (Read 1446 times)
Offline Ccmp
  • Bike: DL1000 K3
« on: June 04, 2015, 08:26:18 »
Hi , looking for help on clearance check. I have done clearance checks on other bikes before. Doing for first time on a 2009 DL650. When I bring the engine to timing mark “F” the cams do not appear to have released tappets to their uppermost position, ie. where there is clearance. I can continue to rotate until lobes are in correct position. This position is as per service manual. But this bares no relation to the mark at the crankshaft. Apologies if this has been answered numerous times but I’ve done a good trawl with no success.
Offline ziggy
Re: Valve clearance check DL650
« Reply #1 on: June 04, 2015, 09:28:57 »
Sounds like you may be looking 180 degrees out. I.e. check the other cylinder.
Offline Ccmp
  • Bike: DL1000 K3
« Reply #2 on: June 04, 2015, 12:39:46 »
Thanks for reply. Manual is very specific and markings on bike are F and R  for front and rear. Any other bike I checked was just a matter of rotating crank to the marks and checking tolerances. With this, bringing mark F to mark doesn't tally with cam position.
I should note the bike has been running fine.
Offline mjc506
« Reply #3 on: June 04, 2015, 14:15:11 »
Bear in mind that the crankshaft rotates twice as fast/often as the camshafts... Two rotations of the crankshaft is one cycle.
Projects:
« Reply #4 on: June 04, 2015, 14:25:36 »
The cam lobes should not be pointing directly away from the buckets on the F mark. On that mark, the piston is either on the compression stroke or the exhaust stroke. The service manual shows how to determine which is which by looking at the cam lobe position.
Some other useful resources are
http://blacklabadventures.com/2012/02/1 ... djustment/
http://www.vstrom.info/Smf/index.php/topic,3595.0.html
Offline Ccmp
  • Bike: DL1000 K3
« Reply #5 on: June 04, 2015, 16:20:21 »
Thanks again for taking the time to reply. I put the lobes in the position indicated in the manual. All clearances front and rear cylinder are within spec.  The lobe position does not bear any relation to  mark F and R. on crank. Am I missing something obvious?
Offline Ccmp
  • Bike: DL1000 K3
« Reply #6 on: June 04, 2015, 16:26:13 »
Greywolf I had already read those guides. Both mention rotating crank to marks and then readings are taken. When I'm at the marks the lobes are not in correct position ie. no clearance. Clearance good when lobes are in correct position.
« Reply #7 on: June 04, 2015, 16:53:20 »
It's a combination of the mark and the lobe position. If you're on the mark and the lobe position is wrong, rotate the crank 360 degrees to return to the mark. Then the lobes should be in the correct position. The only way that wouldn't work is if the engine was built wrong.
Offline mjc506
« Reply #8 on: June 05, 2015, 08:49:49 »
Have you got any photos?
Projects:
Offline Ccmp
  • Bike: DL1000 K3
« Reply #9 on: June 11, 2015, 12:50:18 »
You're spot on. By the time I got everything stripped my brain must have been bypassed. Anyway all clearances fine. Thanks for help.
Offline mjc506
« Reply #10 on: June 11, 2015, 16:55:00 »
Good to hear :thumb:
Projects:
