Author Topic: engine temperature  (Read 2213 times)
Offline dalou
engine temperature
« on: May 26, 2015, 22:08:06 »
Hi there, just a couple of quick simple questions, I have K7 DL1000 and normally I can be out all day and the temp gauge never goes above 2 bars unless I'm in traffic then maybe sometimes it mights occasionally sneaks up to 3 bars but soon goes back to two bars until the other day ..... so I'm in the middle of doing all the normal checks ..... the only thing that has changed is I have serviced my bike the other day. any ideas?
the other thing was that my uncle has the DL650 on a 10 plate and his normal temp he said is on three bars .... would that be right or is his running high? :shrug:
Offline dalou
Re: engine temperature
« Reply #1 on: May 26, 2015, 22:16:18 »
quick update .... it seems that the fan is not kicking in  .... I can normally hear it just after the temp his three bars but I have had the bike running now for 20 min and its been on two bar for 5 min ..... its never hit 3 bars on tick over
« Reply #2 on: May 27, 2015, 08:06:13 »
Quote from: "dalou"
The old shape 650 runs on three bars  :thumb:
« Reply #3 on: May 27, 2015, 08:40:59 »
My Glee always runs at 3 bars. Don't think the fan comes on unless it's unusually hot and I'm stopped with the engine running.
ProfG
« Reply #4 on: May 27, 2015, 08:43:32 »
3 bars is normal unless you are on an extended run where the air will cool the engine and you will get 2 bars. The fan will kick in at around 4 bars especially in traffic.
Offline dalou
« Reply #5 on: May 27, 2015, 11:39:40 »
thanks for clearing that about how many bars.
now I'm just stick with my issue now with my fan not working .... any suggestions :shrug: on quick ways to check if its the fan that's not working or something else
Offline Babel
  • Bike: DL650X K9
« Reply #6 on: May 27, 2015, 14:00:10 »
Did your servicing include a coolant change? Could there be air in the system? When I last changed the coolant on my Wee there was a significant top-up of the coolant required after the initial fill and a quick test ride to shake it all about.
Offline Big Al wi the Vee
« Reply #7 on: May 27, 2015, 14:07:01 »
I had similar worries about my K7 DL1000, my fan wouldn't kick in at all.
 :shrug:
I took her to my back street fixer, and he said it was one of two things: Fan Fxxked or Temp Sensor.
I changed the fan, which didn't fix my problem, so I changed the Temp sensor, that worked :occasion-balloons:
The temp sensor ( on the DL1000) is on the lower side of the radiator and is the cheapest and easiest repair to carry out.
I would go for that first before buying a new fan.
Although, as said in previous posts 3 bars is the norm.
Good luck
« Reply #8 on: May 27, 2015, 15:09:14 »
Normal number of bars for different models as follows. Fan starts after 3 bars showing in all models. None should ever go to 4 bars.
Wee - 3 unless cool and rainy or cold outside, then may drop to 2.
Vee - 2 unless stop and go traffic when hot outside.
Glee and Veek - always 3.
Offline plumps
« Reply #9 on: May 27, 2015, 20:23:13 »
Hi, got a k5 wee and can confirm that enine temp normally at 3 bars, never goes to 4 bars and fan cuts in if stuck in effing never ending roadworks! :thumb:
