My gear position indicator is drunk.
It occasionally shows nothing when switching gears, sometimes skips a gear, once it showed a higher gear when changing down. If it shows nothing continuing to ride it sorts itself out after 100m or so, but it's bugging me.
Just wondered if this was a common problem, I'm going to chase the wires to inspect connectors tomorrow, and check my voltage readings are healthy. This has developed in the last few weeks, no changes to anything electrical in that time.
Unrelated - I hope due to its prior development - I've had for a long time a problem when switching down, whereby the next gear won't engage until I slightly release the clutch. Clutch cable adjustment is good, it seems to be happening more frequently & only change I can think is an oil change with a service ... not sure what else to make of that one yet. Would a heavier oil have such an effect? Dreading some part of the selection forks/cam is damaged as that sounds spendy.
