Author Topic: Spongy Brakes  (Read 7440 times)
Offline vstroman
Re: Spongy Brakes
« Reply #20 on: April 28, 2017, 18:23:25 »
Neat job, do you feel a big improvement? did you change the brake lines/master cylinder as well? thanks.
Offline Hugh Mungus
  • Bike: Fazer 1000
Re: Spongy Brakes
« Reply #21 on: April 28, 2017, 20:35:00 »
Mine didn't come with any back-plates  :fix:
Offline vstroman
Re: Spongy Brakes
« Reply #22 on: June 03, 2017, 00:24:22 »
Did you change the master cylinder as well? I see some recommend installing a bleeder valve up at the banjo on the master cylinder too.
Offline vstroman
Re: Spongy Brakes
« Reply #23 on: June 03, 2017, 22:53:09 »
How do you know whetehr to get the 62mm or 65mm hole offset, suppose it depends which calipers you get, maybe get them first and measure the offset?
Offline Miggs
  • Bike: DL650 L3
Re: Spongy Brakes
« Reply #24 on: June 12, 2017, 10:38:53 »
I also had horribly spongy brake lever and piss poor stopping.
Flushed thoroughly - no change.
Cable tie on all night - much better lever, but still poor braking.
Change to EBC HH sintered pads - MUCH better!
Now happy.
Chippy4467
Re: Spongy Brakes
« Reply #25 on: June 14, 2017, 21:58:49 »
For the ABS version you may wish to check the hoses - the ones that you can see are braided but up behind the forks its just normal Jap rubber hose which given time will go soft and expand under pressure - they did on my 58 plate & I could actually feel them expand between my fingers.
Hel (mentioned already in this thread) in Exeter now produce full set of braided hoses for the ABS version- they had mine as the pattern :)
Makes "Hel" of a difference. No really the difference is amazing and now more responsive than the brakes on my Explorer.
Well worth doing - but then being the first ABS one mine came foc :) (second bike to get that privilege - did the same with CBF1000)
blokes at Hel are very helpful.
Other tip is to use a vacuum unit to draw the fluid through the system - again much easier than forcing it. I use a Sealey hand vac unit having first put PTFE thread on the caliper bleed nipples.
Chippy
