Author Topic: Brake Caliper Bolt trouble  (Read 1039 times)
Offline Big Al wi the Vee
« on: March 20, 2015, 21:30:10 »
My rear brake caliper bolt has decided to go all cheesy, and won't come off . What a pain in the Donkey. Anyone in the Kilmarnock area have a good way of removing the 14 mm bolt?  Would be grateful If someone could tell me where I can get a replacement.  :old:
Offline Holmsey
  • Bike: DL650 L9
Re: Brake Caliper Bolt trouble
« Reply #1 on: March 20, 2015, 21:54:32 »
Have you not greased your bolts ? .... first thing I done was to take the calipers off and do the pads and bolts.
Makes life easier .... going to do the engine bolts soon as they are a bit rusty  :shock:
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Offline Locky
« Reply #2 on: March 20, 2015, 22:14:51 »
I'd order a new bolt from somewhere like  http://www.robinsonsfoundry.co.uk/  then set about removing the bolt.
Can't picture it in my head but is there access to get mole grips to it ? Or drill it and use a
http://www.ebay.co.uk/itm/8-Piece-Stud- ... 5b0ad676ce
I have a set of these that work well
http://www.ebay.co.uk/itm/Irwin-Bolt-Gr ... 58bfd73ec8
Or maybe the cheapest way is to get a sharp cold chisel and tap it round to unscrew it.
« Reply #3 on: March 20, 2015, 22:25:07 »
Greased my bolts app two years ago, hardly use the rear brake. A combination of brute force and incorrectly fitting socket..... Result, round bolt head.  :ty:
Offline biglad
  • Bike: DL650 L3
« Reply #4 on: March 21, 2015, 07:21:48 »
Drilling it out with an extractor is one way.
Saw a groove across the bolt head, then put a cold chisel/screwdriver in the groove and tap it round.
Heat up the bolt head, with a small blow torch.
Get hold of 'Plus gas' - this stuff really helps sticky threads.
These are tips and tricks I used to get caliper bolts off a BMW r100r that had stood out for some years.
Offline V-Strom3
« Reply #5 on: March 21, 2015, 07:30:27 »
Have you tried a gator socket?
A socket with a lot of pins in it which are spring loaded, can grip rounded bolts.
« Reply #6 on: March 21, 2015, 08:14:25 »
Thanks for all the comments, just ordered the removal kit from fleabay.
