Author Topic: error c44  (Read 2166 times)
Offline cowdenc
error c44
« on: November 02, 2014, 05:37:09 »
hello people of the strom ^^
I finally ended this afternoon getting my bike on dealer mode.
it shows c44 heated oxygen fault...
I refered on all post about this error... everyone says to cut the #24 wire, some says #8
BUT there's no such things connected to my ecu on these ports.... it has little rubber cap instead....
I'm lost....
Offline Hugo Magnus
Re: error c44
« Reply #1 on: November 02, 2014, 07:37:52 »
Wouldn't it be better to cure the disease rather than to treat the symptom?
Offline putbinoot
Re: error c44
« Reply #2 on: November 02, 2014, 09:14:04 »
I had that fault on my 04wee, replaced lambda censor on exhaust and fault gone and better running.
Offline cowdenc
Re: error c44
« Reply #3 on: November 02, 2014, 09:29:37 »
yes I'd rather cure the disease of course, but I may not have explain myself clearly... maybe because english is not my native language
I would replace the sensor if there's one, but there's not even a hole on the exhaust pipe.
also my ecm/ecu have its pin #24 & #8 filled with little rubber "tits", it looks like its from factory...
I don't understand why its showing me c44 error when apparently the ecm itself is not programmed to receive that kind of information...
 :stirpot:
and I just came out from a ride. the bike started to choke... and then turned off showing "CHEC" on the dash.... hopefully right at home....
Quote
CHEC shows up on the LCD panel when no communication signal from the ECM is received for several seconds.
Check the wiring harness between the ECM and speedometer couplers.
The possible cause of this indication can be as follows:
Engine stop switch is in the OFF position.
Side-stand/ignition inter-lock system is not working
ignition fuse is burnt.
google found me this... I remember the previous owner of the bike told me I had to change the ignition fuse... thus I didn't... I crossfingers... I can't afford a new vehicule
Re: error c44
« Reply #4 on: November 02, 2014, 13:11:46 »
Quote from: "cowdenc"
Yep, English isn't your first language.  :)
But it's a great image forming in my head  :shy:
Offline Jacko
error c44
« Reply #5 on: November 02, 2014, 13:42:16 »
I've been searching for them all morning, can't find them. Maybe they're an option?
Re: error c44
« Reply #6 on: November 02, 2014, 15:27:03 »
···filled with little rubber "tits"···
My twisted mind is now running riot...! lol
Offline cowdenc
Re: error c44
« Reply #7 on: November 02, 2014, 21:37:59 »
google is offering me nipples and hooter as alternative.... won't help I guess hahahhaha
plot twist btw... it's the side stand who cause the trouble. the bike engine started this morning.
-- I'm happy
