Author Topic: Aux fusebox  (Read 178383 times)
Offline vstroman
Re: Aux fusebox
« Reply #620 on: July 10, 2018, 12:57:52 »
Thanks Bigpie.
Offline raff113
  • Bike: dl650xt 2021 yella
Re: Aux fusebox
« Reply #621 on: July 12, 2018, 14:34:20 »
Thanks Bigpie
GSF Bandit 600 '02
FZS Fazer 600 '00
SV1000 '03
GSXR1000 k3 '04
KLE 650 Versys '10
DL650X AL7 '18
Tracer 900 '17
MT09 '13
DL650 XT 2021
Re: Aux fusebox
« Reply #622 on: July 12, 2018, 21:41:28 »
Glad you went for it raff, it's a good bit of kit
Offline P248
  • Bike: BMW R1250GS (it replaced my DL1000 GT K7), KTM RC8, Suzuki GS1000EC (one owner from new in 1979, me!)
Re: Aux fusebox
« Reply #623 on: July 28, 2018, 11:34:05 »
Hello Bigpie, do you still do headlight relay kits for K7 Vees? I've just stripped out the faulty HID kits installed by the previous owner and reinstated the original Suzuki lighting set up, but I'd prefer to run the headlamps through relays. I've already got one of your aux fuse boxes installed.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #624 on: July 28, 2018, 12:20:10 »
I don't make them in batches or keep components in stock. I just make them to order. PM if you want one
Offline P248
Re: Aux fusebox
« Reply #625 on: July 28, 2018, 15:34:34 »
Bigpie, I've sent you a PM (I think!)
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #626 on: July 28, 2018, 16:59:35 »
Replied. Btw if anyone is after a fuse box I've got one left
Offline Chris
  • Bike: Suzuki V Strom 650 2012
Re: Aux fusebox
« Reply #627 on: August 02, 2018, 10:43:00 »
Hi bigpie
is there one fuse box left from the last batch that I could order?
Please PM me for money transfer details if so.
Thansk in advance
Chris
Offline Dave L
  • The older I get the faster I was......
  • Bike: DL650 AM3
Re: Aux fusebox
« Reply #628 on: September 01, 2018, 05:56:48 »
Hi Big Pie,
I am interested in a 3 way relay box - I have a satnav, power outlet and heated grips all connected directly to my battery - and it's a mess.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #629 on: September 01, 2018, 08:00:52 »
Hi, I need to make some more up. I'll post when I've got some ready.
Offline Chalkmyster
Re: Aux fusebox
« Reply #630 on: September 30, 2018, 09:00:09 »
Quote removed
Can I order one please?
Regards,
Chalky,
Offline Chalkmyster
Re: Aux fusebox
« Reply #631 on: September 30, 2018, 09:19:51 »
think I may need 2 as I have 5 outputs: horn (soundbomb), jacket, spots, satnav/phone and autocom/radio.....whilst some of these have low draw and I could double up but I want them separate....makes sense?
Any thoughts?
Regards,
Chalky,
Re: Aux fusebox
« Reply #632 on: September 30, 2018, 09:28:07 »
I wouldn't bother wiring  heated clothing through a relay, just connect it to the battery. The idea with a relay controlled supply is you cut the power to the auxiliary devices when you leave the bike, so they are not using power when the ignition is switched off. By default you will be wearing any heated clothing when you leave the bike, so you will have to to unplug it from the bike anyway.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #633 on: September 30, 2018, 09:53:23 »
I don't have any made up at the moment. As TP says, I wouldn't and don't connected my heated vest and gloves through it.
I would also assume your horn uses a relay as it'll draw more than the stock horn and it'll only draw when the button is pressed so can go direct to the battery too.
Offline Chalkmyster
Re: Aux fusebox
« Reply #634 on: September 30, 2018, 18:57:40 »
OK, that makes sense....just thought with a bit of OCD and keeping one source from aux :) .
When do you think these (only need one) will be available bigpie?
Regards,
Chalky,
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #635 on: October 03, 2018, 20:36:04 »
I've put an order in for components and will be making up some more. PM if you want one.
Offline Dave L
  • Bike: DL650 AM3
Re: Aux fusebox
« Reply #636 on: October 04, 2018, 06:48:13 »
Hi Bigpie,
Yes, I would like a three terminal version.
Please notify me when it is ready. I am away in Scotland on the bike all week next week but will be home the following week.
Offline Dave L
  • Bike: DL650 AM3
Re: Aux fusebox
« Reply #637 on: November 02, 2018, 15:49:04 »
Hi Bigpie,
I finally got around to connecting up my Aux Fuse box. It seems to have gone well, everything works as it should and my hot grips and Satnav switch off when the ignition is switched off - result.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #638 on: November 02, 2018, 16:13:11 »
Nice one. Everyone installs them neater than I have done.
If anyone else wants one, pm me.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #639 on: January 23, 2019, 13:21:51 »
I've got 1 of these left then I'll be discontinuing them in favour of a new version that I'm working on at the moment
