Author Topic: Aux fusebox  (Read 178426 times)
Offline pichulec
  • Bike: KTM 1290 SAS
Re: Aux fusebox
« Reply #580 on: April 21, 2018, 10:25:40 »
Ill take one
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #581 on: April 21, 2018, 10:44:49 »
Pm'd got one left at the min
Offline Gary lad
  • Bike: SUZUKI DL 650 AK7 GT
Re: Aux fusebox
« Reply #582 on: April 23, 2018, 12:08:07 »
Hello bigpie
Can you help trying to locate the wire I connect the unit too is it just two wires a white and orange colour as I can only find this one which is very tight to get too which is under the water tank
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #583 on: April 23, 2018, 12:13:39 »
It's hard to see from the photos but it sounds right, they're easier to get to on some bikes and if you have small hands. Put the fusebox connector between them.
The wires are orange and a black/white. See https://www.ebay.co.uk/itm/Rear-Brake-Light-Switch-for-2005-Suzuki-DL-650-K5-V-Strom-/391254890382
Offline Trumpton
  • Bike: DL650 AL2, Pulse Adrenaline 125
Re: Aux fusebox
« Reply #584 on: April 23, 2018, 15:27:48 »
Hi all
I fitted the bigpie fusebox at the weekend to my DL650AL2.
The connection was tricky to find as it was the right beneath the part of the loom that sits beneath the coolant bottle
See picture below.
great fusebox Bigpie, thank you
Offline Gary lad
Re: Aux fusebox
« Reply #585 on: April 23, 2018, 16:25:58 »
Cheers I  think it’s the correct wire bigpie and thanks for the last photo may help the wire is under the water bottle very tight to get at
Online cb1300rider
  • Bike: 2005 650 VStrom, ST1100, honda c90
Re: Aux fusebox
« Reply #586 on: April 23, 2018, 19:52:32 »
All received thanks Bigpie.....yet to be fitted but looks a very smart bit of kit .
Thanks very much
Offline Gary lad
Re: Aux fusebox
« Reply #587 on: April 24, 2018, 10:29:27 »
OK fitted the unit all done a bit of a struggle but all OK
Now trying to fit Sat Nav wires plugged into unit done turn on power not charging but if I attach wires from satnav direct to battery it charges
 I removed the 2amp fuse from original inline and  plug into new unit nothing any help please
Re: Aux fusebox
« Reply #588 on: April 24, 2018, 10:47:01 »
Gary, that fuse is physically too small for the socket. It isn't able to touch both terminals. Go to BMS across road from the big Tesco on Huddersfield road and ask them for blade fuses. They should be able to help. :fix: :thumb:
Don't forget to fit a fuse in the main inline fuse holder too. Your pic above shows you have no fuse in there. The inline fuse needs to be about 10 amp but the individual fuses from the relay need to rated suitable to the item it is feeding.
Offline Gary lad
Re: Aux fusebox
« Reply #589 on: April 24, 2018, 11:27:59 »
Hello Paul
This 2amp blade is from the inline fuse holder original wire so put this back in there get that but don’t know which blade fuse I have to put in the unit not good with electric
You still near me if struggling ha just seen your profile you moved
Re: Aux fusebox
« Reply #590 on: April 24, 2018, 11:55:10 »
Sorry mate, I moved away last year. I would have been round to help if I was still over there. The 2 amp fuse in the inline holder will be OK for running a Sat Nav on its own. You will also need a 2 amp fuse  in the fuse holder with the relay in your second pic.
Offline Gary lad
Re: Aux fusebox
« Reply #591 on: April 24, 2018, 12:35:33 »
Hi Paul lowest they do is 3 amp
Re: Aux fusebox
« Reply #592 on: April 24, 2018, 13:08:25 »
That will be fine then.  :thumb:
Offline Gary lad
Re: Aux fusebox
« Reply #593 on: April 25, 2018, 09:34:47 »
Thanks to bipie for this fantastic bit of kit works great on my satnav
 Also thanks to Paul for the info about the fuses thought I just took the fuse out of the in-line and put into the new system drr
Much appreciated blokes
Re: Aux fusebox
« Reply #594 on: April 25, 2018, 09:50:13 »
No worries mate, glad you're up and running.  :thumb:
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #595 on: April 25, 2018, 09:51:14 »
Cheers TP. Glad you're up and running.
Offline vstroman
Re: Aux fusebox
« Reply #596 on: May 04, 2018, 00:20:15 »
I've already got your headlight relay kit installed Bigpie, electrics are a mystery to me so excuse me if I'm talking rubbish,
I have various things connected directly to the battery, must be half a dozen dif things connected :shy:
would this be what I need to do away with all the battery connections I'm also looking at fuseblocks.
Offline pichulec
Re: Aux fusebox
« Reply #597 on: May 07, 2018, 15:42:37 »
Fusebox installed nice and neat, Thanks bigpie
Offline JhT
  • Rookie
  • Bike: Black Glee L2
Re: Aux fusebox
« Reply #598 on: May 07, 2018, 15:47:30 »
Hi!
My Glee is need of a set of aux lights and heated grips (she was moaning about that this morning)... hehehe.
Bigpie, would be possible to get one of this fusebox when you get some more ready, please?
I believe it is the wiser way to fit new electrical bits to the bike.
Thank you!
1971 Mobylette Motobecane》Daelim S-Five》Daelim S2》Honda CBF》Suzuki V-Strom
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #599 on: May 07, 2018, 16:00:16 »
No problems. I'm a little busy at the moment with my electric trials bike project, but I'll be making some more asap.
