Author Topic: Aux fusebox  (Read 177892 times)
Offline Vic929
Re: Aux fusebox
« Reply #320 on: November 10, 2015, 16:41:34 »
Think the strobe could be handy whilst filtering through traffic
Offline Toddy64
Re: Aux fusebox
« Reply #321 on: November 10, 2015, 20:38:56 »
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #322 on: November 13, 2015, 12:34:35 »
The banggood lights was easy to disable the 3 modes. The circuit board in mine was labeled as tw-713h-v4 and I just removed the whole IC labeled U2. Now I just have high beam. I can post after photos if anyone needs them.
Offline kwarr
  • Bike: 2012 Glee
Re: Aux fusebox
« Reply #323 on: November 14, 2015, 16:55:03 »
Impressed  :) :) :)
Got it (partially) installed, it took me longer to find the connector it than it did to wire it in :-O
Needed to push pull wiggle the existing wiring. Also had to remove the reservoir briefly to give me enough room. Anyway, Sat Nav installed - I don't really like the wiring route (I've'e got a Cymarc bracket so the Garmin is above the instruments) so wire trailing down on the R/H side, not elegant but functional!!
Anyway, spotlights over the next couple of days and maybe red led bullets to 'use' the last connection on the fuse box.
ps the Sat Nav worked fine..... after I remembered to install the 2nd fuze - Doh !!
Offline Andyonbass
  • Bike: 2014 DL650
Re: Aux fusebox
« Reply #324 on: November 19, 2015, 21:43:43 »
Any news on whether a new batch is iminent? I have been dropping hints to the missus regarding electrical additions for xmas......  :icon_wink:
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #325 on: November 20, 2015, 10:14:54 »
I wouldn't say imminent, I've just got back off holiday. Looking looks like I've got some interest so I aim to make some more before Xmas
Offline Andyonbass
  • Bike: 2014 DL650
Re: Aux fusebox
« Reply #326 on: November 20, 2015, 16:01:45 »
great! Put me down as a definite when you have them,,,,,, :thumb:
Offline kwarr
  • Bike: 2012 Glee
Re: Aux fusebox
« Reply #327 on: November 25, 2015, 19:40:28 »
Buggeration!!! Whilst installing the fuse box I musta disturbed the wiring of my (dealer installed) cig charge socket wiring!!! Its always been a bit 'flaky' and I've'e had to fiddle to get the plug connected properly (usually mini tyre inflater.) Its also in a rather inconvenient place - so as I have already drilled the top plastic panel for the spot light switch, I think I'll pull it and replace and re-locate the/a socket to the panel.
Still v happy with fuse box though and all acc's fully functional :-)
Offline kwarr
  • Bike: 2012 Glee
Re: Aux fusebox
« Reply #328 on: November 26, 2015, 17:24:39 »
I know this is prob now in the wrong thread...but  the cheapo eBbay spots I added draw too much current cos there's not enough ummmph to power the heated grips if the spots are on!!!!
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #329 on: November 26, 2015, 18:28:52 »
What heated grips do you have and which spots?
Offline kwarr
  • Bike: 2012 Glee
Re: Aux fusebox
« Reply #330 on: November 26, 2015, 20:09:08 »
Dealer installed Suzuki oem when I bought the bike (Oct 2011, 2012 model). However.... I suspect that (like the cig charger socket) they might NOT be Suzuki!!!
lights were 'cheapish' £35. "Universal Fog / Spot Lights Ideal For Kawasaki GTR 1400 / KLE 650 / 1000 Versys".
to be honest - they are obviously from China, horrible mounting brackets, and I stripped one thread on the body, and I hardly did the nut up!! Also they are very big, so I had already bought some replacement LED spots from BikeVis in anticipation....
Offline Gramps
  • Bike: GSXR750 SLINGSHOT, lambretta GP225, PX200, DL650
Re: Aux fusebox
« Reply #331 on: December 06, 2015, 21:05:22 »
Hi all, how do I go about getting one of these aux fuse boxes. do I just pm bigpie, or just wait and hope he see's this post, still new to the site so unsure how to do things in manner that does not pee people off. Yes I am crap with electrics I will end up like this :angry-banghead: then it will be like this :bawl: so any help would be great.  :ty:
Re: Aux fusebox
« Reply #332 on: December 06, 2015, 21:40:38 »
Bigpie reads this all the time, so he will see this real soon.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #333 on: December 06, 2015, 23:08:00 »
Hi, I don't have any at the minute. I was hoping to make some more before Xmas but I'm a bit snowed under with work at the moment.
I do intend on making up another 10 as soon as I get chance.
Offline kwarr
  • Bike: 2012 Glee
Re: Aux fusebox
« Reply #334 on: December 11, 2015, 17:58:53 »
Just to let you know... swapped my cheapo fleabay spotlights for some BikeVis LED spots, they work fine AND I can have the heated grips on at same time.
Also added some BikeVis rear red bullets to the third feed from the fusebox. All works hunky dory, so very pleased with the fuse box. Happy days. :lala: :lala: :lala: :lala:
Offline corkyballs
Re: Aux fusebox
« Reply #335 on: December 27, 2015, 09:52:17 »
I'll register my interest for a fuse box from the next batch please Bigpie
Offline Kimbles
  • Bike: 2014 Vstrom 1000 in red
Re: Aux fusebox
« Reply #336 on: December 27, 2015, 14:33:03 »
Hi,
Can you put me down for one on the next batch aswell please it would be appreciated  :ty:
Kim
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #337 on: December 27, 2015, 15:06:10 »
Will do. Hopefully get chance once Xmas is out of the way
Offline bigrob
Re: Aux fusebox
« Reply #338 on: December 27, 2015, 15:36:35 »
Can I just ask how much are these now?
Any chance to help me fit as I am in Rotherham as well?  :lala:
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #339 on: December 27, 2015, 15:43:17 »
Was 27 quid last time. No problem re fitting.
