Look for other sources of vacuum leaks too. That split hose you mention is one example. If you spray some WD40 around the throttle body area and the exhaust suddenly gets smoky, there is a vacuum leak where you last sprayed. Sometimes the caps on the intake vacuum ports used for throttle body synching deteriorate and cause vacuum leaks for example.
