Clutch bite on the Glee today
Topic: Clutch bite on the Glee today (Read 787 times)
Joe Rocket
Bike: DL650A L5, Kawasaki GPX750R
October 04, 2014, 21:34:17 »
I had one concern on the new bike I rode today and that was the clutch bite, it started to engage only 5 mm from the handlebar grip. I assume this is just adjustment on the cable at the engine end because at the handle bar it was almost out of thread. Just a small detail.
It wasn't properly set up I think. I've always had engagement near the end of lever travel leaving 5mm of play at the lever fully out (unless things have changed on newer bikes) ?
Joe Rocket.
Jacko
Bike: DL650 L2
Re: Clutch bite on the Glee today
October 04, 2014, 23:03:23 »
Needs adjusting. My bite has been fine from day one, nice and progressive, after 9,000 miles. It's certainly a lot further out than 5mm.
greywolf
October 04, 2014, 23:08:10 »
Besides the cable ends, there is an adjuster in the cable body where it looks like a snake swallowed a sausage link.
Matt-EUC
October 05, 2014, 00:05:11 »
Mines fairly close to the bar but closer to the middle of travel.
I'm at 17.5k miles and going strong
tallpaul
Tastier than the Barrow-in-Furness bus depot...
Bike: 2016 Yamaha XT1200ZE
October 05, 2014, 02:10:50 »
Quote from: "greywolf"
Now there's a description that messes with your head!
Joe Rocket
Reply #5 on:
October 05, 2014, 09:38:54 »
Thanks for the replies, adjustment as suspected. Funnily, the salesman checked the oil level in the little window after I came back! (I think he was showing me where it was..........
Joe Rocket.
