Author Topic: 3500 rpm popping and juddering help!!!  (Read 5805 times)
Offline KLV
Re: 3500 rpm popping and juddering help!!!
« Reply #20 on: October 19, 2014, 12:21:52 »
I put iridium plugs in mine and after a 1000 miles did exactly what yours is doing, was in Italy at the time, luckily I had the ones I had just taken out under the seat, swapped 'em and it was fine! Happened on a mates TLthou too...... Seems these motors need the stock type plug in......
« Reply #21 on: October 19, 2014, 14:41:58 »
It really sounds like the wrong reach plugs were involved. The correct Iridium plugs work very well for a long time.
Offline vstrom2007
  • Just Stromming Along
  • Bike: 1000 AL8
« Reply #22 on: October 19, 2014, 18:51:33 »
Offline vstrom2007
  • Bike: 1000 AL8
« Reply #23 on: October 19, 2014, 19:06:47 »
thanks martin for the edit, this shows the difference between the ngk CR8EK and the shorter CR8HIX, but throttle body sync valvles checked as its on 24000 miles now, :auto-dirtbike:  new plugs and power commander back on and remapped to eliminate a slight hesitation at 2500 rpm and booom the stroms back better than its ever been
Offline shaboy
« Reply #24 on: October 19, 2014, 19:42:00 »
glad to hear the bikes running good now mate,now get that black shit off your werx pipes.hope to see you soon mate.dave.
« Reply #25 on: October 19, 2014, 19:54:51 »
The correct Iridium plug is the CR8EIX.
Offline vstrom2007
  • Bike: 1000 AL8
« Reply #26 on: October 19, 2014, 21:17:14 »
Quote from: "shaboy"
already polished n ready for the next trip just got to get a air bed again bro
Offline vstrom2007
  • Bike: 1000 AL8
« Reply #27 on: October 19, 2014, 21:20:44 »
Quote from: "greywolf"
thanks greywolf it just goes to show don't always believe what eBay suggests as the right item, but I'm leaving it well alone for now as they're changed well before there time anyway.
Offline Essex Performance
« Reply #28 on: October 19, 2014, 23:53:11 »
Quote from: "vstrom2007"
Glad to hear the bike is running well again John  :thumb:
I have PMed Jok re the running lights
Thanks mate
KR
Steve
Offline vstrom2007
  • Bike: 1000 AL8
« Reply #29 on: October 20, 2014, 08:02:47 »
Welcome to the club Steve and the dyno and  map you  put on has just totally smoothed the bike out now right through the Rev range. I now finally have the bike running how it should and thanks again .  :auto-dirtbike:
Offline putbinoot
« Reply #30 on: October 20, 2014, 16:03:11 »
that will be you up to 30mpg :neen:  will pm you book links.
Offline Goodlad
« Reply #31 on: October 23, 2014, 15:17:52 »
I had the exact same issue. I looked like a complete spa driving through a town and of course cruising along the fecking revs were sitting arounf 3500 and the bike was spluttering all over the place.
Once I put on aftermarket exhausts the issue just got worse. Once I put a power commander onto the bike the issue stopped. Pulls like a stuck now with the dynojet map. Will get a custom map sometime in the future
