Author Topic: rear wheel knock  (Read 1347 times)
Offline Strommerboy
  • Bike: DL 650 k9 with 43000 miles
rear wheel knock
« on: September 14, 2014, 21:50:43 »
Wheeling my K9 Wee back last night the normal click of the chain on sprocket was accompanied by an unusual knocking sound. After putting the bike on the centre stand and rotating the wheel backwards I was able to identify the knock as being near the rear sprocket. The sound, though not loud, was accompanied by a vibration of the chain. The knock didn't occur when the wheel was rotated forwards. Both front and rear sprockets and chain appear to be in good order.  The wheel seems to have no play in it. I'm wondering if this might be a wheel bearing issue. Any thoughts?
Re: rear wheel knock
« Reply #1 on: September 14, 2014, 22:06:52 »
See if you can lift the rear caliper up. Its carrier might not be keyed to the swingarm.
Offline user650
« Reply #2 on: September 14, 2014, 22:22:11 »
Tight chain link possibly  :shrug:
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline Robotstar5
  • Bike: DL650K5
« Reply #3 on: September 14, 2014, 23:01:11 »
Quote from: "user650"
You normally hear a tight link on the front sprocket first due to it's smaller diameter.
Offline Manora
« Reply #4 on: September 16, 2014, 14:15:28 »
Check the sprocket bearing, you will need to remove the back wheel to check properly. The bearing is housed in the sprocket side of the cush drive.
Should have no play and be smooth when rotated.
Peter
Offline Strommerboy
« Reply #5 on: September 20, 2014, 19:56:00 »
Thanks for the replies. The issue was resolved today when the bike was taken in for a service. The chain had been overtightened a touch when my new tyres were fitted.
Offline Joe Rocket
« Reply #6 on: September 21, 2014, 19:35:22 »
Better a slack chain than a tight one, I think that was the cause of a rear sprocket carrier bearing going on my last Yamaha.  :shy:
Joe Rocket.  :)))
