Author Topic: Awful fuel consumption  (Read 1461 times)
Offline Mick_P
« on: September 12, 2014, 21:24:00 »
Hi,
My Vee is only doing about a hundred miles to a full tank. First couple I put down to it being new to me etc, but it's not got any better. Anyone got any ideas of what - if anything - might be causing it?
It's a K2, 51K and runs fine. I know it had an injection system done as 38K in 2009 and the last service was in Oct 13 and it's only done about 1.5K since then. They did indicate they thought it might have a fuel pump/ECU problem but fitted new plugs which seemed to work.
I have noticed that if I turn the ignition on too quickly the FI light stays on in both modes, but if turned slowly it's fine.
No drips or leaks noticed, and a petrol smell only when the engine it hot from slow riding in traffic.
The only other thing of note is that it has gone down the road at some point, on the left side as far as I can make out. It has what appears to be new switchgear on the right (starter, lights etc).
Ta,
Blue AN400, Connie III
Proud Yorkshire/Welshman
Don't follow me, I'm usually lost.....
Caution, ABBA fan!
Re: Awful fuel consumption
« Reply #1 on: September 12, 2014, 21:30:02 »
Blimey! Are your brakes binding? You've either got a fuel leak or only three gears. How many litres do you put in to fill it up after 100 miles?
Offline Mick_P
« Reply #2 on: September 12, 2014, 21:56:09 »
lol. Brakes aren't binding And I fill up when the fuel pump symbol starts flashing. Around town I rarely get into 5th - that's Ipswich for you. I can't find any drips and there's no smell of petrol except as per my first post.
Caution, ABBA fan!
« Reply #3 on: September 12, 2014, 22:17:38 »
Make the FI fault come on, put it in dealer mode and get us any codes showing, that'll be a good start.
Offline Mick_P
« Reply #4 on: September 12, 2014, 22:45:46 »
Um, silly question: how do I do that?
Caution, ABBA fan!
« Reply #5 on: September 12, 2014, 23:25:45 »
Offline kissofdeath
  • Bike: Veek
« Reply #6 on: September 12, 2014, 23:27:13 »
this will help
http://www.vstrom.info/Smf/index.php/topic,7061.0.html
make sure you have the seat off before you get the fi fault and don't switch it off until you have the code otherwise you will lose the error
Offline kissofdeath
  • Bike: Veek
« Reply #7 on: September 12, 2014, 23:28:08 »
ahh you beat me to it  :bawl:
Offline TLPower
« Reply #8 on: September 13, 2014, 06:28:08 »
Throttle position sensor could require adjustment, what does the temp guage show? If it's reading low poss thermostat causing it to run on the cold map.
Air filter OK and no obstructions to the airbox?
Check that the correct spark plugs were fitted.
No sign of exhaust damage?
Also check that the air inlet temp sender is connected on the left hand side, green plug, during the collision repair it may have been left off, or mixed up with the engine temp sender. Try swapping the connectors.
Offline Holmsey
  • Bike: DL650 L9
« Reply #9 on: September 13, 2014, 18:29:57 »
when you park the bike up for the night , do you turn the ignition off ???  :shrug:
Sorry ... just being flippant  :shy:
I have not got a clue, did get my MPG up from 44 mpg to 66.7 mpg by sensible riding.
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Offline Mannakin
« Reply #10 on: September 16, 2014, 16:00:20 »
Bear in mind that the indicator on my Vee tends to come on after I've used around 17 litres - so it's not a full tank you have used.
Still I normally get 140-150 miles between filling up and the light flashing but that's normally fairly fast motorway running.
Offline Mick_P
« Reply #11 on: September 18, 2014, 21:16:19 »
Right, apologies for the delay, other things intruded.
I'm only getting a C42 error, which is the ignition switch signal anti theft thingy, so I can't see that being the problem (unless I'm wrong, lol).
So the next thing is to start having a bit of a delve I reckon.
Any connections I should make sure are clean as I'm intending to take the tank off and check everything to do with the fuel system and a couple of other jobs while I'm at it, like fit a manual switch for the fan.
Thanks for all the suggestions, much appreciated.
Caution, ABBA fan!
