Author Topic: Chain & Sprockets .. what to replace them with  (Read 996 times)
Offline sjh
« on: September 07, 2014, 21:25:46 »
So at 18k my front sprocket is showing more wear now, chain and rear sprocket look good but I intend to replace the lot together. I clean it every 800 miles or so, but I'm still quite impressed that the stock chain has made it this far and looks so good.
My choices seem to be DID x-ring bells and whistles type kit chain, another Suzuki set, or something else entirely.
Does anyone here have any strong opinions either way? I like to try different things and don't mind spending more for better kit so going.
Re: Chain & Sprockets .. what to replace them with
« Reply #1 on: September 07, 2014, 21:27:20 »
DID X-Chain on mine, with JT sockets. Co-incidently, changed at 18001 miles, so you have another mile to go yet  :)
Offline sjh
« Reply #2 on: September 07, 2014, 21:31:51 »
Good to know, my local shop is < 1 mile away.
I'm leaning to the DID chains, I think I saw a 25k warranty on one, but I guess sprockets would go well before that. Any reason for the JT sprockets?
Do people generally find a difference in drive chain noise between manufacturers also? Since fitting the airflow screen I can really hear it!
« Reply #3 on: September 08, 2014, 00:24:59 »
JT, Renthal, Sunstar, Supersprox or Talon sprockets. DID or EK chain everytime, avoid Renthal chains and only use rivet links :thumb:
Offline mjc506
« Reply #4 on: September 08, 2014, 08:58:56 »
If you're bothered about chain noise, you may want to get another stock front sprocket - the Suzuki item has a rubber 'ring' around it to dampen chain noise, whereas anything else (including the 15t and 17t options) will have no such thing and may be slightly noisier.
I notice mine at low speeds, especially turning left (the noise bounces off the road surface I guess) but it doesn't annoy me. I also haven't refitted the sprocket cover, which I suppose doesn't help haha
Projects:
« Reply #5 on: September 08, 2014, 19:03:02 »
mjc506 - You're riding without the sprocket cover  :shock:  :shock:  :shock:
Offline Jacko
« Reply #6 on: September 08, 2014, 21:07:02 »
My DRZ doesn't even have a sprocket cover. :)
« Reply #7 on: September 08, 2014, 21:13:17 »
Your 5000th post too  :occasion-balloons:
« Reply #8 on: September 08, 2014, 21:24:01 »
I change the chain and sprockets every 15k miles on the strom.
DID X-ring and JT Sprockets.
I'm lazy with chain maintenance and the scotoiler does the oiling,  :shrug:
I'm just looking at chains for the Super Sherpa and I look at the cheap ones and know they won't last.
« Reply #9 on: September 08, 2014, 22:32:16 »
Don't have a sprocket cover on my DR-Z either, had to remove it as the shifter can't adjust high enough for my off road boots with the cover on.
Offline sjh
« Reply #10 on: September 08, 2014, 23:38:43 »
Thanks for the input all,
Quote from: "mjc506"
That's interesting, do you know if any third party ones do the same? I feel like trying different everything :)
Offline mjc506
« Reply #11 on: September 09, 2014, 08:43:36 »
None that I've seen I'm afraid. I do wonder if you could remove the rubber from a stock one, but I can't imagine it being easy to attach it to another sprocket.
Quote from: "MartinW"
Yup, not died yet :haha:
Projects:
