Tyre Repair
Topic: Tyre Repair (Read 2634 times)
1monkey1
Tyre Repair
August 25, 2014, 20:20:07 »
I went out for a ride today. On return I found this
What do you think, can it be repaired safley?
Or is it fooooked
When everything is coming your way, you're in the wrong lane.
TLPower
Bike: ThunderBastard (KTM 1190 ADV)
Re: Tyre Repair
August 25, 2014, 20:26:34 »
I had a similar object in mine, I had it plugged. No issues in the following 4600 miles which included 3 dyno sessions and 2 trackdays.
But I'm from Yorkshire tha sees.
bigpie
Site Donator
Bike: DL650
Re: Tyre Repair
August 25, 2014, 20:28:49 »
That should be repairable I'd say. It's right on the tread and central, though I've had them done between without problems.
Locky
Bike: Triumph Tiger 800xc & Yamaha TTR250
Re: Tyre Repair
August 25, 2014, 20:32:51 »
Yes it can be repaired. There's plenty plug kits on the market but most on here like these
http://www.stopngo.com/
I've'e done most of my own punctures over the years without problems.
Or get it done at your local bike shop.
Bobstar222
Re: Tyre Repair
August 25, 2014, 20:39:55 »
I got one done on the Veek at a local Asian worn tyre lock up for a fiver and done 2000 miles on it.
Timmo
Re: Tyre Repair
Reply #5 on:
August 25, 2014, 20:44:41 »
Unscrew it and don't pull it out maybe obvious but just in case.I've had ones with little heads and massive threads that act like a bloomin file and make a mahoosiv hole instead of one that will close up nicely
1monkey1
Re: Tyre Repair
Reply #6 on:
August 25, 2014, 20:50:19 »
Thanks lads.
I have a plugging kit, I bought a few years ago. I take it with me when I go to Europe.
In a funny sort of way I have been itching to use it.
MartinW
Administrator
Bike: DL650 K4 Blue
Re: Tyre Repair
Reply #7 on:
August 25, 2014, 20:55:44 »
Quote from: "1monkey1"
Me too, God knows why.
Locky
Re: Tyre Repair
Reply #8 on:
August 25, 2014, 21:00:10 »
Used a few different plugging kits over the years and had good results with all of them. For a very small hole I use these
http://www.ebay.co.uk/itm/Motorcycle-Qu ... 2c7e6d03ca
My rear tyre has been repaired with the above earlier this year and I also repaired a puncture in one of my van tyres last year with the same kit.
Also carry one of these and always had good results
http://www.ebay.co.uk/itm/REMA-TIP-TOP- ... 3ce5dc3723
Have a look on youtube, plenty of demo's..
Jacko
Bike: DL650 L2
Re: Tyre Repair
Reply #9 on:
August 25, 2014, 21:42:39 »
Get it off and have it plugged properly, with a mushroom and vulcanising solution. Talk nicely to your local tyre fitter, tell him it's for track use only if he has any reservations.
Tyre Repair
