Author Topic: Re: Clock - Changing Times  (Read 1142 times)
Online Hugo Magnus
« on: August 17, 2014, 14:53:22 »
When you've worked it out let me know :grin:
« Reply #1 on: August 17, 2014, 15:22:03 »
Don't take up skydiving. It could get messy...
Offline Oop North John
« Reply #2 on: August 17, 2014, 15:39:00 »
Have a look at this thread:
viewtopic.php?f=58&t=21922
Offline Holmsey
  • Bike: DL650 L9
« Reply #3 on: August 17, 2014, 15:39:37 »
It's not difficult  :shrug:
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
« Reply #4 on: August 17, 2014, 15:56:53 »
Is the problem you can't get it into clock mode, or, that when in clock mode you can't adjust the clock?  :shrug:
« Reply #5 on: August 17, 2014, 15:57:55 »
The simultaneous part can be tricky. If the ADJ button is pressed just slightly ahead, it won't work. Pressing the left button slightly ahead works fine so do that. The ignition switch has to be on and the kill switch needs to be in the run position.
Offline Jacko
« Reply #6 on: August 17, 2014, 16:10:05 »
I just leave mine set to BST.
Offline Holmsey
  • Bike: DL650 L9
« Reply #7 on: August 17, 2014, 16:16:23 »
If you want to know the time ask a policeman.
I do have a watch  :)
IBA Member
« Reply #8 on: August 17, 2014, 16:41:01 »
Quote from: "Michelle_B"
Thanks all. John, it just not highlights clock.
Hold the select lever for 4 seconds, that toggles the ambient temp / clock. If you see the odometer / trip /mpg changing, hold the select lever for longer.
Offline Jacko
« Reply #9 on: August 17, 2014, 17:24:52 »
Oh, was that it? I could have told you that. ;)
« Reply #10 on: August 17, 2014, 17:42:24 »
John,
Just came back from garage. All done. You are a star  :star:
Thank you
Easy when you know how, glad to be of help  :thumb:
Offline Holmsey
  • Bike: DL650 L9
« Reply #11 on: August 17, 2014, 18:47:46 »
So you have a clock in the garage then  :grin:
When the big hand points to twelve and the little hand is on six  :)
IBA Member
Offline Holmsey
  • Bike: DL650 L9
« Reply #12 on: August 17, 2014, 19:17:54 »
if your worried about the time when your riding your bike, perhaps you shouldn't ride  :neen:  lol
IBA Member
