Grease build up on gear box
Topic: Grease build up on gear box (Read 735 times)
DB100
August 08, 2014, 13:56:41 »
Hello Group -
I am new to this group having just purchased a 2005 DL1000. I love it and am really excited to be back on two wheels.
I fairly thick when it comes to mechanics, so pls bear with me. I hope someone can appease my concern here.
I have been riding for 6 weeks now. I noticeds yesterday some grease build up on my shifter (?) and looked closer to see where the source was coming from. It apeears to be from the gear box. IS this normal?
I Have only riden about 1000 KM since buying the bike. I bought it from a dealer and it was serviced prior to me taking ownership.
I Have photos but can not seem to upload them through this discussion forum....you know a picture says a thousands words..
ANy advice would be greatly appreciated.
frez
Re: Grease build up on gear box
August 08, 2014, 14:08:36 »
If you mean from behind the front sprocket cover this is normal, grease is flung off the chain and collects in there, simply remove the sprocket cover and scrape it all out and you should be good for a long while.
MartinW
Administrator
Bike: DL650 K4 Blue
August 08, 2014, 15:08:50 »
Hi DB100 and
Pop over to
Introductions
and say hello.
Here's some pictures of my bike's front sprocket just before a clean.
After a good clean, I got the two looking quite good. That last little bit in the corner of the cover needed parafin to get clean.
greywolf
August 08, 2014, 15:34:17 »
http://www.vstrom.info/Smf/index.php/topic,1886.0.html
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
August 08, 2014, 20:09:04 »
+1 for using paraffin, few things as good as it for cleaning greasy stuff. Just make sure you have a plastic container below to everything so it's easy to clean up.
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
