Fuel Filter DL1000 (K2)
Topic: Fuel Filter DL1000 (K2) (Read 608 times)
Fat Rat
Administrator
Bloke/Geezer/Fella
August 02, 2014, 18:24:43 »
I'm not at home so I can't check. Can someone tell me if there is anything special about the fuel filter on a K2 DL1000? Is it just an inline filter? Is it 6mm or 8mm?
Ta
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
greywolf
Re: Fuel Filter DL1000 (K2)
August 02, 2014, 18:44:30 »
No Strom has an inline fuel filter in stock condition. All have a screen at the pump intake and a very expensive high pressure filter as part of the pump assembly. Going to an inline filter is a popular fix for a clogged filter.
http://www.vstrom.info/Smf/index.php/topic,3981.0.html
http://www.vstrom.info/Smf/index.php/topic,6105.0.html
Note specifically any work on the outside line has to be done with a high pressure hose, clamps and filter. Everything has to hold up against a constant 43psi. Stuff made for carbs or low pressure injectors won't cut it.
