Author Topic: Rev Counter problem  (Read 580 times)
Offline Ricky1000
Rev Counter problem
« on: July 26, 2014, 12:01:28 »
Was out yesterday for a run and noticed the rev counter take on a will of its own. Needle jumping up and down from zero to red line. Seems to start when speed is about 55mph and moving through gears. When at a steady speed and not useing gears appears to work normally.
Anyone had a similar problem. Could it be a bad connection if so where is the connection.
Keep her lit
Re: Rev Counter problem
« Reply #1 on: July 26, 2014, 14:28:21 »
There is a large connector under a rubber cover in the left side of the fairing as well as the connection to the instrument case itself and the ECU.
Offline Ricky1000
« Reply #2 on: July 26, 2014, 15:37:24 »
Spot on Greywolf. Big connector on the left cleaned reconnected problem sloved.
Keep her lit
