Author Topic: Custard TLC  (Read 15061 times)
Offline Jacko
Custard TLC
« Reply #40 on: July 27, 2014, 23:20:02 »
Is that a bolt kit or just a load of bolts bought at the right size?
I'd like to replace all the ones I take off the Glee in the coming years as I remove and replace them under normal maintenance.
Re: Custard TLC
« Reply #41 on: July 28, 2014, 09:40:17 »
It's just bolts of the right size, I tend to buy at least 10 at a time of any given size.  :)
Re: Custard TLC
« Reply #42 on: July 28, 2014, 15:21:54 »
For anyone interested, I used Stainless Socket Cap Bolts..
Water Pump
M6 x 30 (2 of)
M6 x 65 (3 of)
M8 x 10 (1 of)
M8 Copper Washer (1 of)
Clutch Cover
M6 x 30 (9 of)
M6 x 75 (2 of)
Offline Abercol
  • Bike: 2016 Explorer XRT
Re: Custard TLC
« Reply #43 on: July 29, 2014, 10:39:44 »
I'm interested....my Clutch basket and waterpump covers are off and I too await John Sharealike's kind attention to the clutch basket....might as well order up some bling while I wait....
I still need to clean off the gasket faces. Just as well its forecast sunny tonight (bike work carried out in driveway).
Re: Custard TLC
« Reply #44 on: July 31, 2014, 21:01:58 »
My Clutch Basket is due back tomorrow, just as I leave for a weekend of nights in London  :bawl:
Re: Custard TLC
« Reply #45 on: August 01, 2014, 12:37:09 »
Arrived as promised (thanks John).
Re: Custard TLC
« Reply #46 on: August 03, 2014, 18:49:06 »
I'm just back after some grueling night shifts in London  :bawl:
I'm waiting for my lovely assistant to get back tomorrow (Daughter not Diver)  :) and then I'm determined to get Custard back together.
Because I couldn't help but get my hands dirty this evening I did the worthwhile tasks of fitting some new Plugs.
Offline Shebee
Re: Custard TLC
« Reply #47 on: August 03, 2014, 20:58:59 »
Quote from: "Fat Rat"
.  Oooh shiny stuff
Re: Custard TLC
« Reply #48 on: August 07, 2014, 22:40:07 »
I am the tiredest bloke in the world. I drove to London yesterday afternoon, worked until 4am then drove home again.
Somehow I found the energy to crack on with the reassembly. I did okay, got everything back on, Oil and Coolant in and I started her  :)
Unfortunately I have an oil leak, some knob (me) hasn't put one of the Rocker covers on properly  :violence-smack:
Tank off in the morning and hopefully all will be well.
Re: Custard TLC
« Reply #49 on: August 08, 2014, 10:14:22 »
Yeah we only did them hand tight.
Re: Custard TLC
« Reply #50 on: August 08, 2014, 11:35:44 »
I've had them off again since your visit Nathan, so I can't even blame you  :shy:
Re: Custard TLC
« Reply #51 on: August 08, 2014, 11:42:34 »
Offline kissofdeath
  • Bike: Veek
Re: Custard TLC
« Reply #52 on: August 08, 2014, 12:14:07 »
looking good  :clap:
Re: Custard TLC
« Reply #53 on: August 08, 2014, 14:32:39 »
After re-seating the Rocker Cover I still had a slight oil leak, on closer examination it was making its way past the threads on one of the bolts  :shock:
I have ordered a Helicoil kit but won't have time to make the repair until next week  ###
For anyone interested, the Rocker bolts are M7.
Offline macvisual
Re: Custard TLC
« Reply #54 on: August 08, 2014, 15:41:09 »
wOw, you're doing a fantastic job on that custard DL thou, makes great reading, well done yourself, dedication alright. Have you thought about changing both front headlamp bulbs to the likes of Osram brighter/whiter bulbs.....?
And whilst your at it, you could order a two tooth more rear sprocket (Renthal) for more oomph, it does make a better improved/difference, trust me, mines been replaced for nearly a year now and wouldn't go back to the standard sprocket...........ever.
Have fun.
Pete
Re: Custard TLC
« Reply #55 on: August 08, 2014, 17:25:46 »
I've never felt the need to enhance the Strom lights, they are the best from any bike I have ever owned  :)
Re: Custard TLC
« Reply #56 on: August 08, 2014, 17:32:11 »
That Halfords Silver Wheel paint isn't a perfect match but I think it looks okay..
c]
Because the Tank has to come off to repair the thread in the head this is as far as I can go until next week  :GRR:
Rear plastics, Sump Cover and Rear Carrier back on.
Re: Custard TLC
« Reply #57 on: August 08, 2014, 19:11:52 »
Mr. Rat, those cam cover bolts all appear to be missing a rubber gasket, that's probably why it's leaking.
Number 25 in the diagram:
http://www.suzukipartshouse.com/oempart ... inder-head
ps. I was hoping for another glimpse of your more attractive helper :GRR:
Re: Custard TLC
« Reply #58 on: August 08, 2014, 19:19:52 »
If only  :)
The washers are there Juv, I had wound the bolts back in so I didn't lose them.
Re: Custard TLC
« Reply #59 on: August 08, 2014, 19:21:26 »
Too bad, that'd be a real easy fix :(
