Author Topic: Custard TLC  (Read 15062 times)
Custard TLC
« on: July 16, 2014, 11:38:50 »
This is Custard :shrug: a K2 Suzuki V-Strom DL1000 that I have picked up, it needs some TLC to get her roadworthy again.
The first task was to take the first four layers of grime off so I can see what's what. Lots of black parts returning to silver.
One Exhaust Stud has sheared and the other feels like it will. Any magical tips to get them out? The one already sheared has enough thread to grab with a pair of Mole Grips.
Next is draining the old fuel and fitting a new battery.
Offline Iggy
Re: Custard TLC
« Reply #1 on: July 16, 2014, 11:53:10 »
Quote from: "Fat Rat"
Plenty of heat usually does the trick - and as the engine finish is already pretty scabby, you won't do that any harm either....
 :fix:
Iggy
Brand loyal ?  Nope - anything will do if its got two wheels and an engine !
Re: Custard TLC
« Reply #2 on: July 16, 2014, 12:40:34 »
I hear good things about Plus-gas.
Re: Custard TLC
« Reply #3 on: July 16, 2014, 12:53:40 »
I've been applying Plusgas since last night, fingers crossed.
Re: Custard TLC
« Reply #4 on: July 16, 2014, 17:38:32 »
It's in pretty good condition.
The previous owner lost enthusiasm with the bike when his head was turned for another (we all know how that goes)  <!-- s:) -->:)<!-- s:) -->
The combination of a few faults meant it was left unused for an extended period. I'm encouraged at how well she is cleaning up. I have removed the sheared studs, reassembled the exhaust (replacing one clamp) and replaced a blown sidelight (actually I replaced both while I was in there).
I even took her for a ride up the driveway  <!-- s:auto-dirtbike: -->:auto-dirtbike:<!-- s:auto-dirtbike: -->
I've optimistically booked her in for an MOT tomorrow, once she is through that I will start stripping  her. The Clutch Basket will be on its way to John Sharealike on Monday  <!-- s:fix: -->:fix:<!-- s:fix: -->
Re: Custard TLC
« Reply #5 on: July 18, 2014, 12:57:36 »
One of the sheared studs came out with heat and Plusgas, the other had to be drilled (although that went well, 7mm drill and then cleaned the thread with an 8mm tap)  :)
Just before taking her for an MOT I realised that there was no dip beam  :GRR:  went straight to the connector behind the Radiator and sure enough, lots of corroded terminals. An hour of cleaning later and 'let there be light'  :)
She went in for MOT this morning and passed without any advisories.  :lala:
However...
I took her for a blast when I got home and noticed the dip beam flick on and off a couple of times. She is going on the bench now for a strip down. Once I have all the Plastics and Tank off I will look at the look at the loom.
Jobs to do;
Strip
expose, clean and seal all wiring connections
Plugs, Oil, Filters
Check Valve Clearances (Diver is going to be my lovely assistant on Sunday)
Chain & Sprockets
Remove Clutch Basket and send to John Sharealike
Clean & paint Engine & Water Pump housing
Check/replace Water Pump Seals
Clean/Paint Radiators
Clean/Paint any corrosion
I have to remember that this is a K2 with 40k on the clock and don't want to spend a fortune on her but most of these jobs just require time rather than dosh.
Re: Custard TLC
« Reply #6 on: July 18, 2014, 17:03:00 »
Seeing as "strip" and "expose" are the first two jobs, then please don't photograph them.
However, keep the reports going on the rest of the work.  :)
Re: Custard TLC
« Reply #7 on: July 18, 2014, 17:05:32 »
Assistant   :angry-tappingfoot:
Offline Locky
Re: Custard TLC
« Reply #8 on: July 18, 2014, 17:49:01 »
Yes plenty pics make it more interesting , ffs give Diver a better title  lol
Re: Custard TLC
« Reply #9 on: July 18, 2014, 18:06:40 »
No, 'Lovely Assistant'.
Truth be told, Diver will be showing me how to check Valve Clearances  <!-- s:) -->:)<!-- s:) -->
Re: Custard TLC
« Reply #10 on: July 18, 2014, 18:28:46 »
OK, I had an intermittent dip beam problem, I opened up the usual suspects and cleaned and sealed.
The fault was in the right hand connector on this picture
There was one terminal that was too far gone so I cut the wire out of the connector, soldered and heat shrunk.
Then it was time to remove the Clutch Basket ready to send to John Sharealike
Offline Locky
Re: Custard TLC
« Reply #11 on: July 18, 2014, 18:29:08 »
Lovely ? He's a big hairy arsed Welshman  lol
Re: Custard TLC
« Reply #12 on: July 18, 2014, 18:31:53 »
I have also removed the Rad & Oil Cooler for TLC/Paint
Re: Custard TLC
« Reply #13 on: July 18, 2014, 19:35:04 »
Streetfighter?
Re: Custard TLC
« Reply #14 on: July 18, 2014, 20:03:49 »
Street fighter? Looks like it's been beat up already! lol
Offline Robotstar5
Re: Custard TLC
« Reply #15 on: July 18, 2014, 21:07:47 »
Swap the bars for clip-ons - cafe racer?
Re: Custard TLC
« Reply #16 on: July 18, 2014, 21:56:46 »
Sheepfrightener
Re: Custard TLC
« Reply #17 on: July 18, 2014, 23:30:51 »
Are you making Karen work on your bikes? That's not your arms or chest! :grin:
Re: Custard TLC
« Reply #18 on: July 19, 2014, 00:21:56 »
That's Diver dressed as my lovely assistant  :)
Or it could be my daughter  :)
Re: Custard TLC
« Reply #19 on: July 19, 2014, 10:47:40 »
:text-datsphatyo:
