Author Topic: FOOT PEG LOWERING KIT  (Read 859 times)
Offline PHIL FAT
« on: July 15, 2014, 20:13:29 »
has anyone put any pictures of foot peg lowering kit fitted to their bike from cymarc bike parts have orderd some but just wanted to see what they should look like fitted thanks in advance
Too Old To Die Young
Offline kissofdeath
  • Bike: Veek
Re: FOOT PEG LOWERING KIT
« Reply #1 on: July 16, 2014, 06:37:37 »
will sort some later for you :)
Offline PHIL FAT
« Reply #2 on: July 16, 2014, 18:47:04 »
well kit arrived this morning fitted the one gear leaver side no problems now the problem started to undo the bolts on the brake lever side one came out OK the other would not shift don't want to put too much pressure on the bolt we all know they are made of cheese any help loosening it would be helpfull
Online Fat Rat
« Reply #3 on: July 17, 2014, 04:22:21 »
See the Product Review section  viewtopic.php?f=92&t=18734
Offline kissofdeath
  • Bike: Veek
« Reply #4 on: July 17, 2014, 12:32:29 »
sorry been a little busy to take the fotos, but 1 of the bolts was extra tight on mine as well, just make sure you use a very tight "tool" with plenty of length  :)
« Reply #5 on: July 17, 2014, 15:40:57 »
A lesson for us all, I'm sure...
Offline PHIL FAT
« Reply #6 on: July 17, 2014, 20:34:49 »
OK thanks for that will give it a go friday
Offline tony f chelmsford
« Reply #7 on: July 26, 2014, 20:58:10 »
Did you finally fit the lowering kit OK phil? Happy with the result? Am interested in getting some for mine
Cheers tony
Offline PHIL FAT
« Reply #8 on: July 26, 2014, 21:18:26 »
sorry I am late replying got the last bolt off with brute force using a socket set with an allen key attachment now all fitted I do like the differance in height and well worth the money the only thing is the brake switch linkage you get a small piece of wire that looks like a paper clip to extend the spring did not use it just put the spring in a vice and stretched it  works a treat would recommend this item paid for on the monday and arrived on the tuesday
