Author Topic: new strom cuts out/backfires/stalls on pull away  (Read 69694 times)
Offline bosnjo
  • Bike: DL1000 L7
Re: new Strom cuts out/backfires/stalls on pull away
« Reply #300 on: February 16, 2015, 08:37:22 »
Next week I'm lifting the tank to check those wires and protect them, probably with the plastic spiral you use to roll your computer cables in, to keep them together. Here is example photo:
Also, I want to check the connector behind the radiator and see what I can do to protect it against water.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
Offline oddbod
« Reply #301 on: February 16, 2015, 13:22:14 »
Laava,
Yep I see your post and plan to lift the tank next weekend to take a look and put some preventative measures in place. My cutting out issue has been from day 2 of picking the bike up so doubtful its chaffed wires but you never know. Will also be taking a look at the connector block behind/above the radiator too.
As I said, only two test runs so far (I don't get to use the bike until wknds) but so so so much smoother and responsive with the new exhaust, combined with the previously adjusted TPS to 28.9 and remap.
Silently chuffed, but mindful it may not be permanent!
DL1000 2014 Red
DL650 2012 White (sold)
Offline wunwinglow
« Reply #302 on: February 16, 2015, 13:47:48 »
Hmmm.. Wiring an easy check. Oddbod, where did you get your can from? None of my googled suppliers seem to have it available.
Thanks all for contributing to this thread!
Tim
Offline frez
« Reply #303 on: February 16, 2015, 13:52:11 »
Ebay from Italy? It's how I got mine for the S10.
Offline bosnjo
  • Bike: DL1000 L7
« Reply #304 on: February 16, 2015, 14:30:17 »
I got my Arrow from Spain, far lowest price:
https://www.motorraiz.com/
DL1000 2017 white
Offline Oop North John
« Reply #305 on: February 16, 2015, 14:59:32 »
I got my titanium Arrow end can from WRS in Italy. They do trade on eBay after adding a few pounds to the online price.
Offline oddbod
« Reply #306 on: February 16, 2015, 15:59:25 »
£313 on egay.... http://www.ebay.co.uk/itm/231423982409
Lovely jubbely. Try it wunwinglow, I love it!!!!
DL1000 2014 Red
Offline wunwinglow
« Reply #307 on: February 17, 2015, 01:07:53 »
Muchas gracias, Senor oddbod!
Tim (practising for October....)
Offline oddbod
« Reply #308 on: February 17, 2015, 09:00:43 »
No worries Tim.
Hope you enjoy.
You off to Spain again then? I'm trying to get to the Alps again this summer. 2 weeks through Germany, Austria, Leichtenstein, Switz. Will hurtle through France at beginning and end. Hopefully no sudden health issues will arise this time lol.
How the bike running though?
DL1000 2014 Red
Offline wunwinglow
« Reply #309 on: February 19, 2015, 12:47:56 »
Yes, in October hopefully. Like last time, but not quite so long a trip this time. I wrote a little article in my bike groups latest magazine, although watch out for a couple of mistakes; for example we went to Santander, not Barcelona!!! It was very late when I was typing....
http://bam-members.org.uk/bamadmin/2015-16-Issue46.pdf
Tim
Offline oddbod
« Reply #310 on: February 19, 2015, 15:43:10 »
excellent, great stufffffff
DL1000 2014 Red
Offline bosnjo
  • Bike: DL1000 L7
« Reply #311 on: February 19, 2015, 19:45:19 »
Quote from: "Laava"
I recommend you have a look at these wires as I will bet I am not the only person this will happen to.
Thanks to warning Laava posted here, I went through full check of those wires and found heavy rubbing signs. Solved it now and making separate thread about the problem.
Thanks Laava !!
DL1000 2017 white
Offline Simmo24
  • Bike: 2020 KTM 790 Adventure
« Reply #312 on: March 01, 2015, 17:54:13 »
Had the 600 mile service done, guess what ?   Yes you're correct , cough splutter on pull away from idle and when the engines hot it's got the idle hammer. To be fair it's not happening all the time , but its there.  :angry-tappingfoot:
Just like described on the Stormtrooper forum "chudder chudder clack clack" , what do they do on that 600 mile service ?  I noticed it almost immediately after picking the bike up. Feels like it's a bit rough accelerating from low revs too. It was perfect before the service. MPG has suffered too, it was aroung 49-50 mpg now its already down to 42mpg.
Our greatest weakness lies in giving up.
Always try just one more time. -Thomas Edison
Offline Simmo24
« Reply #313 on: March 20, 2015, 11:27:47 »
A couple of hundred miles now after the service and the problem seems to have gone away  :shock:
Mind you I had it in for the technicians to check it out, but they couldn't find anything wrong. (Surprise !),
they did however re-seat all those exposed connectors above the radiator and waterproof them at my request, so whether this did anything I'm not sure. It's running fine so far though.  :)  :)  :auto-dirtbike:
Offline pdc3161
  • Bike: Suzuki v-strom 1000 2014
« Reply #314 on: April 11, 2015, 19:55:35 »
I have a 1000 64 plate and mine does the same and my friends to told them on my service 600 about this problem they said Suzuki  know of problem and it's the exhurst bolts loos on back  cylinder  ??  Mine still does it but notas often ??   It now has a knocking noise since service only on back cylinder  going back shop on mon grrrrrr lol
Offline bosnjo
  • Bike: DL1000 L7
« Reply #315 on: April 11, 2015, 20:15:13 »
Your text is a bit confused. If I understood well, exhaust bolts on rear cylinder are loose and Suzuki knows about that? So, it was loose on your bike and after they tighten it, it got better?
Keep us posted on your new visit to a dealer.
DL1000 2017 white
Offline Tanz
  • Bike: DL1000 K7
Re: new strom cuts out/backfires/stalls on pull away
« Reply #316 on: July 26, 2016, 13:13:05 »
Hi did you ever resolve this problem as that sounds exactly the same as what my does
Offline bosnjo
  • Bike: DL1000 L7
« Reply #317 on: July 26, 2016, 13:32:52 »
In the meantime, it has been discovered that ECU swap solves those problems. Mine has been solved with new ECU and many others. There is long thread about new ECU on this forum.
DL1000 2017 white
