Author Topic: fuse help  (Read 1135 times)
Offline bluebullet47
fuse help
« on: March 17, 2014, 19:24:01 »
think I blown a fuse ,I have a [ chec ] code come up and it won't start ,but where is the fuse box :shrug:
Re: fuse help
« Reply #1 on: March 17, 2014, 19:28:28 »
Check your kill switch first...
Re: fuse help
« Reply #2 on: March 17, 2014, 20:15:22 »
CHEC normally indicates the kill switch is not in the run position or the bike is in gear with the side stand down. The fuses are in the black box in front of the battery with "FUSE" cast in the top, but that's not your problem.
Re: fuse help
« Reply #3 on: March 17, 2014, 20:49:03 »
Could we be on for another red-faced "Oh yes, it was the kill switch" type post  :)
Make sure you own up if it is !
Re: fuse help
« Reply #4 on: March 18, 2014, 18:02:09 »
its not the kill switch  lol  . I was putting in a auxillary fuse box and must of nocked  a coupling behind the battery  :eusa-doh: and now the battery is nearly dead [with keep trying to start it is on charge now ] but the fault is still intermitant   :wtf: peed off ,swapted the battery so meny times .but things are looking up its been running . :lala: plus must put a light in the garage [found and checked the fuses] . anyway thanks for the help
 :star:  :star:  :star:  :star: .
Re: fuse help
« Reply #5 on: March 18, 2014, 18:06:43 »
You may have found the one thing that causes a CHEC besides the kill switch or side stand switch. If those are okay, the ECM sends a signal to the display not to show a CHEC. If the system voltage is low or the connection from ECM to display is marginal, the signal from the ECM to the display might not get through and the CHEC is shown.
