Author Topic: Bagster  (Read 1181 times)
Offline geraldo
  • Bike: 2019 DL 1050, 2002 ZRX 1200S, 1995 ZXR 750L3
Bagster
« on: March 14, 2014, 17:41:20 »
Just got a new Bagster Tank cover for my 2010 Wee.
Anyone have any photos of one fitted to similar ??
Should the fixing bolt on the bottom of the black plastic trim go through the hole on the  bottom end of the Cover, if it does then it is really tight and I don't want to damage it....
Going away for a couple of days next weekend and I want it right. :shrug:
Thanks in anticipation.......
Re: Bagster
« Reply #1 on: March 14, 2014, 20:54:13 »
The cover uses the bolt that holds the black tank plastic and the side fairing in place on each side to hold it in place. Get them in and tightened first then you do the strap and the tank and around the front of the frame. It's a good tight fit if you do it properly.
Offline Jeff999
Re: Bagster
« Reply #2 on: March 14, 2014, 21:10:32 »
Take the plastic covers off and put the bolts in as normal. Leave them in overnight then remove them and re-attach the panels and it will remain in situ until you get them tightened..
Offline geraldo
Re: Bagster
« Reply #3 on: March 15, 2014, 07:27:44 »
I appreciate the help blokes  :ty:
I will put it on today......once I've warmed up my garage, bloody freezing up here just now.
Re: Bagster
« Reply #4 on: March 15, 2014, 09:55:59 »
A [s:1yckfznl]3000W[/s:1yckfznl] 1200W halogen heater with 3 elements that you can switch individually is great for a cold garage. Turn it on when you walk into the garage with all 3 bars on and in about 20 minutes you can turn two of the elements off and be cosy all day. You might even start getting too warm and you could turn it off all together.
I have one like this, works a charm:
http://www.ebay.co.uk/itm/380778471396
Offline stibbs
Re: Bagster
« Reply #5 on: March 15, 2014, 10:31:27 »
But that link's a 1200 :shrug:
Re: Bagster
« Reply #6 on: March 15, 2014, 10:42:49 »
I thought it was a 3000W, but it turns out I have a 1200W heater, I just went to go check. That's even better, it'll cost less to run.
Offline geraldo
Re: Bagster
« Reply #7 on: March 15, 2014, 11:11:16 »
I'll be having one of them....
 :ty:
