Author Topic: Need a bit of help.  (Read 1403 times)
Offline Retraite
Need a bit of help.
« on: March 14, 2014, 12:22:48 »
Living in France my new 2013 V-strom DL650 came with a French handbook and I need an English version. I'm working my way through it with my limited knowledge of the language but am a bit stuck on the 'computer dashboard controls.
Suzuki UK have none in stock at the moment so until I can get an English version can anyone advise on what does what.
Re-setting the clock for example.
Thanks.
"Autocorrect is my greatest enema."
Offline Oop North John
Re: Need a bit of help.
« Reply #1 on: March 14, 2014, 12:34:13 »
MPH to KPH
Meter to odometer
Press and hold adjust for 2 secs
Fuel
Total capacity 20L
4.5L left - fuel pump blinks
2.5L left - fuel pump and gauge blinks
Adjust clock
Into clock mode
Meter select (handlebar) &
Adjust button (left of tacho)
simultaneously for 2 seconds
Meter select changes the data
Adjust changes units
Together simultaneously for
2 secs to return to clock mode
Offline Retraite
« Reply #2 on: March 14, 2014, 12:42:33 »
Wow, that was quick, thanks John  :thumb:
« Reply #3 on: March 14, 2014, 13:16:50 »
Quote from: "Retraite"
I have it ready for when I cross over into mainland Europe. And will need it in two weeks time as well when BST starts. Where abouts in France are you?
« Reply #4 on: March 14, 2014, 13:41:14 »
We've got a whole lot of downloads for various Stroms. Go to the top of the page, on the blue bar look for the 'home page' and click it. Then click on 'Downloads'. I hope what you need is there...(not sure if an owners manual is included) You will need Winzip or something similar.
« Reply #5 on: March 14, 2014, 13:52:04 »
The simultaneous button push for the clock change can be somewhat iffy. Push the left button slightly before the right button and it will work every time. Just keep holding both buttons down until the display flashes.
Offline Retraite
« Reply #6 on: March 14, 2014, 15:09:05 »
Thanks for the help - all done  :thumb:
« Reply #7 on: March 14, 2014, 20:49:08 »
