I'm trying to find some not expensive "fog" lights. Found quite a few but they're all 55W each. Before I order, I need to know if I could put 110W extra load on my Glee, as I want to run them day and night. Of course, installation would be done through relay and fuse, and power from the battery.
I also found good LED ones but I don't want them to be different color from main beam, and all LED ones are "Cool White", which means 6000K or over.
I've searched and found LED bulbs H3 "Warm White" 2700K (5-10W) but their size is huge and I doubt they'd fit into housing.
So, a bit of a mess...
The simpliest way would be a pair of 55W/H3 lights. I understood heated grips are arround 50W so I guess connecting 110W to heated grips connector is too much. But that doesn't metter as I can put some extra effort and do propper wiring from scratch.
So, can I put 110W extra load on my Glee?
Thanks
