Author Topic: milky oil  (Read 2817 times)
Offline snaffle
milky oil
« on: March 02, 2014, 16:26:27 »
Hi all,
Glee 2013, New in Dec and only 700 miles on clock. First service 100 miles back and oil now looks like this. The mechanic did mention slight milkyness when changing it at 6oomiles. Bike only commuting 8 miles runs through all this wet weather. Did 100 miles today and interestingly parked up next to another Glee at the Owls Nest, Llandovery and his window was the same.
Do I need to worry?
Re: milky oil
« Reply #1 on: March 02, 2014, 16:28:15 »
You don't need to worry if you are doing short trips in this weather. A long blast somewhere, or commuting again in warmer weather, and everything should be OK.
Offline TrevorKent
Re: milky oil
« Reply #2 on: March 02, 2014, 16:44:46 »
Hi
We had this discussion last year, look at my posts and you will find the thread
Trevor
Offline Jacko
Re: milky oil
« Reply #3 on: March 02, 2014, 16:59:22 »
Quote from: "snaffle"
Do I need to worry?
Not in the slightest.
Offline stibbs
Re: milky oil
« Reply #4 on: March 02, 2014, 17:02:34 »
My old vw beetle had this all the time. Short runs the oil doesn't heat up enough. As others say, give it a blast then it'll clear.. :thumb:
Re: milky oil
« Reply #5 on: March 02, 2014, 17:17:14 »
Offline Holmsey
  • Bike: DL650 L9
Re: milky oil
« Reply #6 on: March 02, 2014, 17:55:16 »
I also have a 'Milky Spy Hole' but the nurse said it will clear up soon. She is a biker and has the same problem ............................. Don't know what your thinking  :shrug:
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Offline KLV-Rider
Re: milky oil
« Reply #7 on: March 02, 2014, 18:21:57 »
Is that after your 100 mile ride?
Offline Holmsey
  • Bike: DL650 L9
Re: milky oil
« Reply #8 on: March 02, 2014, 18:26:00 »
Quote from: "KLV-Rider"
more like 2 minutes  lol
oh sorry !! was that directed at me ??   :shrug:
IBA Member
Offline KLV-Rider
Re: milky oil
« Reply #9 on: March 02, 2014, 18:29:12 »
:shock:  :shock:
 lol
Offline snaffle
Re: milky oil
« Reply #10 on: March 02, 2014, 18:47:31 »
thanks for the replies and interesting comments! Yes that pic was after the 100 mile trip.  :GRR:
Offline Chalkmyster
Re: milky oil
« Reply #11 on: March 02, 2014, 19:30:49 »
That was me :)
My last oil change was about 700miles with some 30 miles when we meet this morning.
Regards,
Chalky,
Re: milky oil
« Reply #12 on: March 02, 2014, 19:52:17 »
It will take quite a while for the milky white to go away. To help you can clean the crank breather sponge in your air box frequently.
Re: milky oil
« Reply #13 on: March 02, 2014, 20:17:31 »
if it's just on the sight glass and inside the filler cap, it's quite normal, I do a 5 ile ride to work and it's exactly the same as yours atm, It will be sorted for a while tomorrow as I'm heading out to West Wales for a day in the lanes.
It'll be back by the end of the week... the mrs 125 doesn't have this 'problem'.  :shrug:
Jen laughed when I said you had 'milky spy hole'
Some have attributed it to pumping action of the twin engine on a bike that gets used through winter for short commutes, sucking in moisture through the air box breathers and the engine/oil not getting hot enough to vaporise the moisture and expel it from the engine casing.
You won't likely get any sense from Dragon Bikers- just scare tactics telling you to get it sorted ASAP.  :text-datsphatyo:
Offline Jacko
Re: milky oil
« Reply #14 on: March 02, 2014, 21:05:34 »
I get it on my four too Diver.
Offline Penfold
Re: milky oil
« Reply #15 on: March 04, 2014, 19:08:04 »
Get it on mine as well no need to worry I was told. All seems too clear up when and if the weather improves.
Re: milky oil
« Reply #16 on: March 04, 2014, 19:15:09 »
took the bike for a 200 mile ride yesterday, it was all gone by mile 50
Offline shameless_frank
Re: milky oil
« Reply #17 on: March 08, 2014, 21:14:01 »
I've had it on mine all winter and at the end of a near 60 mile commute it's still milky. Been told only way to get rid is to change oil, oil filter and air filter
Offline user650
Re: milky oil
« Reply #18 on: March 09, 2014, 00:13:31 »
It's fine don't worry about it just keep riding  :thumb:
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline Jacko
Re: milky oil
« Reply #19 on: March 09, 2014, 07:29:26 »
I think the general consensus is 'ride it more', that'll sort it right out. :)
