Author Topic: f f fork leg leak  (Read 1850 times)
Offline bluebullet47
f f fork leg leak
« on: February 13, 2014, 15:30:38 »
my strom 05 650 dl left fork leg is leaking only had the bike two months anyone got one  :GRR:
Offline mjc506
Re: f f fork leg leak
« Reply #1 on: February 13, 2014, 15:46:23 »
Where's it leaking? If it's out of the seal, an oil seal and dust seal replacement is relatively painless.
Out of the leg... you've got bigger problems! :)
Projects:
« Reply #2 on: February 13, 2014, 15:49:39 »
That normally means a bit of grit is lodged in the seal lip. http://sealmate.net/ shows how to fix the problem easily. A seal mate is a good tool but a bit of photography film or other piece of thin plastic will also work. BTW, I've never had a fork seal leak when running fork gaiters. A search on gaiters will return a number of threads here.
« Reply #3 on: February 13, 2014, 17:11:14 »
Quote from: "mjc506"
it leaks out of the seal don't want to do things like that but I will wait till the sun comes out ,thanks for the Replies [I know how to but don't want to touch it ] :thumb:
« Reply #4 on: February 13, 2014, 19:05:39 »
Your location says you're near Leicester, if you're not to far from Rugby, let me know if you want to visit me for some help. Just rebuild my forks for the... I've lost count... well, just rebuild them again as part of a restoration. I have all the tools one needs to do it quickly, all you need is a set of new oil and dust seals and a litre of 10W fork oil (that's assuming the bushes aren't completely knackered, but that's usually unlikely.)
« Reply #5 on: February 13, 2014, 19:14:46 »
It's unlikely a seal replacement is needed. Run a wiper around it first. If you let every fork leak run you into a seal replacement, you're probably working too hard.
Edit: I misread the age of the bike. The period of ownership threw me off.
« Reply #6 on: February 13, 2014, 23:17:29 »
If something has managed to get past the dust seal to lodge itself in the oil seal to the point where it's leaking then your dust seal is already in need of replacement, it's designed to prevent this. In this case the chances that the oil seal is damaged are high. For the sake of a few quid and some effort I'd rather fix it than faff about 'cleaning' whatever out only to have to fix it properly at a later, likely more inconvenient, time.
« Reply #7 on: February 13, 2014, 23:58:39 »
Quote from: "Juvecu"
That is not always the case. I've seen many reports of leaks disappearing and not coming back after cleaning. It's really worth a try.
Online 2112
« Reply #8 on: February 14, 2014, 06:41:28 »
When was the last time the forks were serviced ? They are probably due an oil change anyway, a great time to pull them apart and check everything over. As Juv' rightly mentions if the bushes are worn the seals will just keep leaking any way even if you replace them. It's not the end of the world to replace the bushes (did some on a YPVS 350LC ages ago) and not as expensive as you might think.
Offline hookie
« Reply #9 on: February 14, 2014, 08:50:41 »
If the bike has gone from 2005/6 to now with original oil and seals then it's really done well, so getting the forks serviced and fitted with new seals will be money well spent. If you continue to run the bike until the weather breaks, just keep an eye on the leaking seal and keep it clean so that no oil finds it's way onto the brake on that side otherwise you'll have to pay for new pads as well as being potentially dangerous.
« Reply #10 on: February 14, 2014, 17:38:41 »
Thanks for all the help and advice ,I won,t be using the bike till I get it sorted thanks .
 juv I might take you up on that very kind offer later  :)
 I love what you did with your bike ,
my bike is an 05 but I have  only owned it about two months   :)
 THANK YOU ALL
Pete
« Reply #11 on: February 15, 2014, 00:20:32 »
Just send me a PM if you want to organise something.
Online Fat Rat
« Reply #12 on: February 15, 2014, 11:47:05 »
Nice offer Juv  :clap:
Any chance you'll nip round and clean mine?
« Reply #13 on: February 15, 2014, 21:04:24 »
Ha! I didn't say I'd do the work, I'll help and I have the tool. Picture me with a nice pale Cornish ale on a stool giving orders  :grin: If you wan to supply the ale I can drop by to sit on a stool and give you some orders too? :shrug:
