There is a black connector behind the rad that is the usualy suspect here.
I had the same exact problem a few months back.
Took all the pins out of the connector and cleaned off the corrosion and all was well.
You can chase the cable from the rhs switches on the bars down to give you the connector that's most likely the problem.
