Author Topic: Time changing on dials  (Read 567 times)
Offline seaninis
« on: October 13, 2013, 13:43:53 »
Bit of help pls gents...I've tried every possible combination of push pull right left in out with the two knobs on the dash board and still can't see how to change the time ...PLEASE help its really bugging. Cheers. Sean
Offline bat-kam
Re: Time changing on dials
« Reply #1 on: October 13, 2013, 14:42:52 »
Ignition on
Both buttons press and hold until the time starts to flash
Release
Press adjust until minutes are set
Press the other button (can't remember the name of it) to change to the hour
Then press adjust to change the hour digits
At the end press the other button once more to save the changes
Kam
Suzuki all the way: '98 Bandit > '99 GSX600F > '09 V Strom DL650 > '09 SV650S > '10 V Strom DL650 > '04 GSX-R 600
« Reply #2 on: October 13, 2013, 14:52:20 »
Push the left button slightly before the right and keep holding both buttons down until the time display starts to flash. Then proceed according to the manual.
