My wee was coming to 18k service so I went ahead and changed oil, oil filter and spark plugs.
Before the plugs were changed when the engine was started in the morning the idle was very unsettled and it sounded as if the front cylinder wasn't firing properly. Once the engine was up to its operating temperature (3 bars) it had perfect steady idle revs.
Two rear plugs were in OK condition
![](http://img.tapatalk.com/d/13/10/10/udy3e7uh.jpg)
But the front plug was in far worse condition
![](http://img.tapatalk.com/d/13/10/10/vudene2e.jpg)
![](http://img.tapatalk.com/d/13/10/10/a8agevu7.jpg)
And the front side one wasn't that good either
![](http://img.tapatalk.com/d/13/10/10/2uja4a7u.jpg)
![](http://img.tapatalk.com/d/13/10/10/y4agehej.jpg)
Since plugs change the idle when the engine is cold is very nice. However, when the engine is up to it's normal operating temperature the idle is a bit nervous. It should hover around 1,3k rpm but it jumps up to 1,5k rpm and then comes down to almost 1k rpm or 1.2k rpm.
I should add that after a minute or so on idle it settles down to the range between 1,3k rpm and 1.4k rpm.
I understand that I shouldn't be very picky and look for silky smooth inline 4 but it should be better then it is at the moment, right?
I was thinking of the valve clearance but Keith, who I bough the bike from, was a bike mechanic for years and been doing the service himself so this shouldn't be a problem.
Is there a way of resetting the memory of ecu?
Or is there something else that I am missing?
Thanks for all the advice in advance
Kam
