Author Topic: Madstad Bracket On Standard Screen?  (Read 4065 times)
Offline JonStromV
« on: September 19, 2013, 21:41:25 »
Subject heading's probably self-explanatory but the question is - Does a Madstad bracket fit to a standard 2007 reg V-Strom 650 windscreen? Has anyone done this and does it work? If so, how tall are you? I'm 6'4"   :)
Re: Madstad Bracket On Standard Screen?
« Reply #1 on: September 19, 2013, 21:46:55 »
Yes it fits, the Madstad mounts are the same as the Wee and K4+ Vee. I use a standard or tinted X screen with mine. I'm 5'11 with a Vee seat on a Wee and I don't have a fat arse.
Offline JonStromV
« Reply #2 on: September 19, 2013, 21:56:27 »
Thanks for that. Anyone know the best place to get a compatible Madstad bracket?
Offline JonStromV
« Reply #3 on: September 19, 2013, 22:18:04 »
Offline jabmotorsport
« Reply #4 on: September 19, 2013, 23:03:09 »
Quote from: "Juvecu"
Who are you trying to convince  :neen:  :neen:  :neen:
Offline JonStromV
« Reply #5 on: September 20, 2013, 21:30:26 »
'ello?
Offline JonStromV
« Reply #6 on: September 20, 2013, 23:00:39 »
May not have explained properly. Can the small extension screen that sits in front and at the top of the main screen be attached to a standard DL650 Suzuki screen? If so, where can the small extension screen be obtained?
Cheers...
« Reply #7 on: September 20, 2013, 23:08:55 »
A madstad screen bracket replaces the black plastic mount between the fairing and the screen.
What your looking for is part of a vario screen. Someone did make one but I forgot who it was and what exactly they called it.
Givi do a vario screen that has the adjustable lip on the top but tou have to buy the whole screen with the lip.
Offline user650
« Reply #8 on: September 20, 2013, 23:40:38 »
See link above same company make just the "blade" to attach to standard screen
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline JonStromV
« Reply #9 on: September 21, 2013, 14:28:40 »
Quote from: "User650"
Thanks Paul...
Offline Tarves Stromer
« Reply #10 on: May 23, 2014, 16:40:34 »
Quote from: "JonStromV"
Hi , maybe you've already sorted this out, but I'm 6'6" and have the madstad with standard screen.  I mounted madstad at highest possible location on the bolt hole options and tilted screen back to about a 60Deg angle.  Works a treat for me.
