Author Topic: brake pads .... again  (Read 663 times)
Offline geekay
« on: September 07, 2013, 15:50:17 »
following my previous note about brake pads and the shreiking / groaning noise at low speed.
I cleaned the brakes with aerosol cleaner and this seemed to get rid of the noise - but a quick ride out the other night showed it was back, albeit much reduced.
I nearly went out and got some more pads, but thought I'd inspect the fitted ones first - removing the pads and cleaning up the calipers / pads etc.
here's what I saw:
OK - not great photos on my phone, but they don't look exactly "worn out" to me - do they?
by my eye, with my metal ruler, there is just shy of 4mm on the pads - uniform across the pad. Probably around 3.8mm if my eye works OK!
They are original pads - made by Tokico if you remove the stainless steel heat shrinks.
Not much copper grease on them - should there be more? any tips for ensuring the brakes are put back together in tip-top shape (or at least "as good as it gets"!)
Offline Jacko
« Reply #1 on: September 07, 2013, 15:53:07 »
Copper grease all the points of contact with the caliper and pistons.
Any wiser as to the cause? Any odd marks on the discs?
Offline geekay
Re: brake pads .... again
« Reply #2 on: September 07, 2013, 15:58:06 »
thanks - no clues - the disc looks great - no marks or circles on it, all looks good.
think the pads look OK? - how thick are new ones?
« Reply #3 on: September 07, 2013, 16:16:19 »
The pads are okay for thickness until a groove is bridged. Plenty is left.
« Reply #4 on: September 07, 2013, 23:59:31 »
Bit of copper or aluminium graphite grease on the back of the plates might help with the squeal. Just a thin layer where the pistons would touch, no need to cover the whole thing (draw two circles with the grease and put the pad back in.)
