Author Topic: help pls  (Read 644 times)
Offline kissofdeath
  • Bike: Veek
help pls
« on: September 05, 2013, 18:40:07 »
need an adapter for the strom, my local garage has a lappy to connect to the bikes but doesn't have the newer 1 for the strom so was asking if an adapter is available. anyone have a clue?
Offline mjc506
Re: help pls
« Reply #1 on: September 05, 2013, 19:11:30 »
The adapter you need is more than an adapter - it's a whole computer in itself, and very expensive/restricted sale.
Why do you need it? Dealer mode gives as much info in terms of FI/ABS errors?
Projects:
Offline kissofdeath
  • Bike: Veek
Re: help pls
« Reply #2 on: September 06, 2013, 12:06:08 »
I thought dealer mode only worked if you did it while the ignition is still on, may be wrong- as usual. had an error when I filled up the other day, switched of then on again and cleared, when put into dealer mode it shows -c 00 so don't know what it was
