Author Topic: Pre-Load Settings?  (Read 984 times)
Offline neltek
  • Bike: V-Strom 650 GT 2010
Pre-Load Settings?
« on: September 05, 2013, 11:14:52 »
OK bit late to ask as have had bike two years
But what is the ideal pre-load for a loaded bike around Europe?
I am 19stone and have 3 large givi cases on too.
Also presuming I do need to ramp up the pre-load - is that turning the rear knob clockwise ?
I know it is in the manual but off later today and could just do with a quick bit of advice  :shy:
cheers
V-Strom 650 GT
ex:
SV650 K6
MZ301
Gilera DNA
Re: Pre-Load Settings?
« Reply #1 on: September 05, 2013, 11:43:50 »
Clockwise is higher, more preload on the spring. I turn it up to full when loaded or 2up.
And if you look at the rings near the top of the shock, 2 showing is stock setting and 5 is max preload.
don't get me to describe set up of the damping... we could be here a while... best thing is never touch the damping adjustment unless you know what you are doing.
« Reply #2 on: September 05, 2013, 12:29:18 »
For best results, Adjust the preload front and rear so the loaded bike uses about 40mm of its suspension travel at each end. http://www.vstrom.info/Smf/index.php/topic,7132.0.html
