Author Topic: Lowering link tech question  (Read 787 times)
Offline G2ADY
« on: September 01, 2013, 20:06:15 »
So after reading that the lowering links from a wee will fit the glee I ordered some from ebay. They've arrived and indeed look as if they will fit but the centres on the dogbones sent (for a 25mm drop) are 145mm, exactly the same as what I have on? I'm just checking, is this standard or do I inadvertently already have a lowered glee?
Re: Lowering link tech question
« Reply #1 on: September 01, 2013, 20:33:24 »
Standard is 140mm. 145mm would cause about a 14mm drop which would be very odd.
Offline G2ADY
« Reply #2 on: September 01, 2013, 21:14:33 »
Hi Greywolf,
So what centres would I be looking for (on a glee) to effect a drop of 25mm?
Best wishes
Steve
Offline G2ADY
« Reply #3 on: September 01, 2013, 22:04:00 »
I've just been out to the garage to double check, the originals do indeed have 140mm centres and the replacements 145mm centres.
« Reply #4 on: September 01, 2013, 22:05:39 »
Quote from: "G2ADY"
Hi Greywolf,
Right around 149mm.
Offline G2ADY
« Reply #5 on: September 01, 2013, 22:29:24 »
Quote from: "greywolf"
Right around 149mm.
That's great, thanks Greywolf, Would you advise dropping the front forks too in order to keep the handling something like it is at the moment?
« Reply #6 on: September 01, 2013, 23:15:02 »
The Glee has a very nice handling setup. I prefer keeping the front to rear relationship by lowering both ends the same amount. There is about a 21mm maximum on the front before the fork legs can crash into the triple clamp though.
Offline G2ADY
« Reply #7 on: September 02, 2013, 01:37:01 »
Thanks so much for your help Greywolf, Really appreciated :)
Steve
Offline G2ADY
« Reply #8 on: September 05, 2013, 21:31:03 »
Just a quick update, links on, front forks dropped, preload back to neutral, I can get my foot flat on the floor! handles a treat too :)
Thanks again Greywolf :)
« Reply #9 on: September 05, 2013, 22:00:08 »
I'm glad I could help. I like the 3/4" lower center of mass.
