Author Topic: My Glee's speedo went erratic then stopped working  (Read 849 times)
Offline Mark Fresh
« on: August 27, 2013, 09:38:40 »
Hi
On a day trip to Bruge yesterday the speedo, whilst cruising at 120 Kmh, dropped, then rose again, then went all random speeds on me. It now sits at 0 no matter what speed I do.
I guess a connector or wire's come loose somewhere, does anyone know where I find it? I see there's a thread about a Wee's speedo but I assume they're different. The bike's only done about 3,000 miles.
Cheers,
Mark
Re: My Glee's speedo went erratic then stopped working
« Reply #1 on: August 27, 2013, 11:03:06 »
My fazer used to do that if it had a loose battery connection...
I think there's a connection just behind the Speedo clocks - I'm sure someone will confirm/correct me
« Reply #2 on: August 27, 2013, 11:17:27 »
Before you rip anything apart, remember you still have a long warranty on this bike.
Offline Mark Fresh
« Reply #3 on: August 27, 2013, 11:23:22 »
Quote from: "MartinW"
Yep, I've got to ride it all week  and I can't get it to the dealer for a week or so, I just wondered if someone had a quick fix as I don't like riding without a speedo.
Offline Oop North John
« Reply #4 on: August 27, 2013, 12:00:09 »
I'd take off the front sprocket cover and trace the wire from the sensor as far as possible. Also, I'd see if I can see any loose connectors between the sensor and panel. Otherwise having a GPS is useful for speed information.
Just looked on Stromtrooper forum and someone there reckoned that their -ve battery terminal being loose caused the speedo to read zero.
Offline kissofdeath
  • Bike: Veek
« Reply #5 on: August 27, 2013, 12:19:12 »
mine did something similar, and turned out to be the sensor on the front sprocket had come off  :shrug:
Offline Jacko
« Reply #6 on: August 27, 2013, 14:14:50 »
Yes, speed sensor on the front sprocket is your first suspect.
