What they said. LED replacements don't have a focused light so are great for additional light when using brights to light up the night. They are bad for fog lights used with dipped headlights where the beam is held low to not blind oncoming traffic and to prevent reflection from fog and rain from coming back to your eyes. I would use the yellow wire in the headlights to activate the relay so they only come on with bright headlights if going to any of the LEDs in the links.
Hmm ... a bit confused
You're saying that they (LED bulbs) are good at night as an additional light (as far as I understand WITH dipped lights), BUT at same time you're saying that they are bad when used with dipped lights as would blind the oncoming traffic BUT you would use it by tapping into yellow wire to use with dipped light... :banghead: I've lost you blokes...
Basically my initial plan was to hook the fog/spot lights with halogen 55w bulbs via relay. I now changed the plan as due to combined high wattage of fog lights will drain the battery. I am now planning to instead of halogen bulbs install LED bulbs (links above). Originally I was planning to connect to parking bulb as I had a plan to have them on occasionally when stationary ... for a bit of show off
BUT without main beam. At the same time I want to use with main headlights.
SO! if I use LED bulbs in current fog lights with relay by tapping into parking lights WILL it work??? Will it make any difference, illumination wise?
Sorry for all the questions .....
