Author Topic: Wolo Bad Boy Airhorn - Fitting Suggestions?  (Read 1413 times)
Offline Descolada
« on: August 16, 2013, 18:02:40 »
I just got a replacement horn for my DL650, the "Wolo Bad Boy" air horn (honestly, you couldn't make that sort of thing up could you). They look like a clone of the "Siebel Nautilus".
Was wondering if anyone else had fitted this horn and where they decided to mount it?
Re: Wolo Bad Boy Airhorn - Fitting Suggestions?
« Reply #1 on: August 16, 2013, 23:16:34 »
I separated the compressor from the horn and mounted the compressor under the seat behind a panel and the horn part behind the fairing at the front of the tank clutch side.
Horn:
Compressor:
Got the idea here:
 http://www.gadgetjq.com/airhorn.htm
Offline Descolada
« Reply #2 on: August 18, 2013, 17:15:39 »
Cool! (the auto-correct changed that, it was actually C.O.O.L)
Thanks very much for the advice, much appreciated.
« Reply #3 on: August 18, 2013, 18:06:05 »
Quote from: "Descolada"
cold! (the auto-correct changed that, it was actually C.O.O.L)
Unless you are talking about temperature the only other reason you would have to use that word is if;
1. You are twelve
2. You are American
« Reply #4 on: August 18, 2013, 18:14:38 »
No need to separate and incur a delay as the line pressurizes. The entire unit will fit inside the fairing on either side. All you need is an earthing rod clamp and a piece of aluminium.
« Reply #5 on: August 18, 2013, 20:31:55 »
I struggled to get the whole unit to fit and in the end I didn't fancy putting such a big horn near the forks in case it moved/interfered with steering. I don't notice any delay when I press the horn.
« Reply #6 on: August 18, 2013, 20:34:35 »
I haven't heard of a single problem being reported with a front frame mount of a full horn and many people have done it.
« Reply #7 on: August 19, 2013, 00:05:54 »
More my questionable skills at mounting it GW rather than a bad idea  :thumb:
